Rattle from sachs clutch. Video?
Hey,
im gonna do my clutch change in a month. Found a SACHS performance kit with pressure plate, flywheel and clutch for a neat price.
However, some people, aswell as the mechanic doing the job told me there will be a rattle sounding from the single mass flywheel when smoothly riding in city traffic etc. "some people does not stand to hear it". Anyone has experience? How bad is it?
Now i'm looking for someone having a video of this rattle? I just want to hear what im getting myself into.
Audi RS4 Avant
[2014]: blacked out wheels & grill: center res delete : flaps open
[2015]: brembo & yellowstuff : michelin pss : h&r spacers
[2016]: sachs performance clutch : decoked : led there be light : black window trim
[2017]: stertman stage 1 : black headlights & clear corner mod : gruppe m air intake : gutted resonators
- NJMAudiRS4
Re: Rattle from sachs clutch. Video?
I have a Loba billeted single mass flywheel with Sachs clutch plate. At low speeds only ie 10/15 mph you can here a whine from the clutch usually in 2nd gear turning into a junction. In 1st if you want to pull away in a stealthy manner you'll get chatter. Normal conditions it's barely audible.
If you irritated by strange obscure noises don't do it.
The upside is a faster spin up and free'er revving.
Audi RS4 Avant. MRC Stage 2 Manifold, caf, Map, JCWF Manifold back Exhaust with Sports Cats, H&R spacers, 449ps & 483nm
- Surrey Sam
Not the same type of car. But I just watched this video and you can hear the type of noise which you'd expect, when the reviewer comes to a stop around 12min 50sec
Had quite a few different clutches in motors
Sounds like car is broke
Stick to oem
Stick to oem
Rs4 phantom black b7 avant : Mrc tuned
- Surrey Sam
Another good example in this other 911R video here at 7min 40sec
Thanks guys!
Well, the clutch kit arrived today and will be on the car within a month.
Worst case i will have to change it again if i dont bare to hear the sound
Audi RS4 Avant
- Robnic
Hi,
I run a Loba Single Mass Flywheel (SMF) with Sachs performance clutch it does have a considerable amount of chatter low down the rev range or if in too high a gear so you learn not to 'load' it too much to avoid that, as a vehicle tech I don't particularly like how much chatter it does cause but as said it is avoidable.
If you purchase a Sachs performance clutch kit without a SMF they do not offer a sprung clutch plate only a solid drive plate (there also offer a paddle plate but not advisable for road use) now this solid plate is designed to replace the OE clutch to be paired to the OE Dual Mass Flywheel (DMF) so the DMF provides some 'damping'
Now I may be wrong but unfortunately I can't remember if the Loba SMF in mine is paired to the Sachs performance clutch kit with a solid drive plate - if so this would explain the considerable chatter I have i.e. no damping on either component - I will find out what clutch I have as the gearbox is coming out of mine in the next few days.
I did try to find out some details from Loba as to what would have been supplied but found them to be f*ck useless coupled with the fact they don't make SMF's anymore
The Sachs performance clutch & SMF kit they offer utilises a 'sprung' clutch centre plate to pair with their own Single Mass Flywheel this should give a reasonable level of smooth take up with not too much chatter.
I spoke to Sachs performance (who I deal with a little through work) they quite rightly said their own SMF's are made to match their own performance clutch kits - the route I wish I had followed
Hope that all makes sense!
Regards
Rob
Regards
Rob
B7 RS4 MTM K540 Sprint loon, Lysholm/Opcon twin-screw supercharger, Ceramics, HEL Hoses, Loba SM Fly, Sachs performance clutch kit, MTM full stainless exhaust system with freeflow cats & quad valved tailpipes, Hotchkis ARB's, Bilstein B16 Coil Overs, LED Rear lights, Interior & LED 50W DRL's, Buckets in race cloth, Black optics, FBSW, Titanium pack, Solar Sunroof, Adaptive lights, MTM 10mm spacers Fr & Rr, 193 Nav unit, 2nd careful owner
Thanks for the great info Rob,Robnic wrote: The Sachs performance clutch & SMF kit they offer utilises a 'sprung' clutch centre plate to pair with their own Single Mass Flywheel this should give a reasonable level of smooth take up with not too much chatter.
i went with this one:
https://www.x1-autoteile.de/index.php?s ... arId=19490
https://www.x1-autoteile.de/document/te ... 000038.pdf
Also, you still have some clutch return pipes in stock, and willing to send to Sweden??
Audi RS4 Avant
- Robnic
Hi,
That is a very good price cheaper than my trade price direct from Sachs!
Yes I can post to Sweden, PM me your address details etc I will be in touch tomorrow
Users browsing this forum: Google Adsense [Bot] and 256 guests
