Quiet alarm
Re: Quiet alarm
Yes as above. He can also fit a GPS module so you can monitor your car from anywhere in the world and lock on unlock it remotely. If you have the remote start too it can start your car for you at a set time in the morning or evening so it is warm / cool as soon as you get in.
Re: Quiet alarm
Another vote for SecureMyCar he knows his stuff
I have the viper Mike mentions
Trick alarm all from your phone
l][
l][
Rs4 phantom black b7 avant : Mrc stage2 manifold: Bmc filter :Black optics exhaust :kW springs :trups led lighting :10mm rear h&R spacers :front 8mm H&R spacers :Carbon front splitter,& oil cooler :Carbon seat backs :hel braided hoses :
Security viper alarm /tracker
Re: Quiet alarm
Can you have that with the push button start? Mine says to press clutch in before starting?
Quiet alarm
Yeah same question, can it bypass the clutch thing? Remote start with out clutch pedal?
RS4 B7 aka Vinnie
RS4 B7 aka Vinnie
Re: Quiet alarm
I normally need to press brake pedal on my 6 to start the car but I have remote start and it works so I imagine the same will apply for the 4 as there is a manual transmission mode which I'm guessing checks it is in neutral before firing up the starter motor.
Re: Quiet alarm
Viper instructions
Assuming you have a newer remote start system that has manual transmission compatibility you can use the following process to enable the vehicle to remote start:
Park your vehicle and put the gear shift into neutral
Apply the emergency brake and release the foot brake
Activate remote start while the car is running off the key
After a few seconds have passed, remove the key from the cylinder and the car will continue to run
Exit the vehicle
Arm the vehicle
The vehicle will shut down upon arming and will be able to remote start as many times as you want until a door is opened or the alarm is triggered
Exit the vehicle
Arm the vehicle
Re: Quiet alarm
What do they charge for that mate
Re: Quiet alarm
Lots of different options so take a look at the link I posted, prices are at the bottom of the page.
But the alarm package is £550.
£150 for the remote start
£400 for the GPS app plus £100 subscription per year for the online part to work (which does loads of things, check out the website or google viper smart start gps). You can always add this at a later date if you wish.
All prices include fitting although if you want it fitted at your house then that starts from £55 depending on how far he has to travel.
Re: Quiet alarm
Here is a bit of info I got before I got mine fitted
Yes we have fitted systems know to hundreds of customers Audi RS4s. As these cars are being attacked for their seats we have design a system which stops them taking the car through key cloning and attacking for the seats.
Below is our full Vw Audi Group (VAG) Upgrade Viper package information and price list;
Over the past 12 months we have seen a large surge in the number of VAG and BMW’s stolen through key cloning across the UK. To achieve this thieves first utilize your factory alarm’s black spot by smashing the corner of the drivers door window to gain access without triggering the factory alarm. The cars OBD port is then accessed, a specialist hand held key cloning device is plugged in and within seconds a new key to your car is programmed. The thief then simply unlocks the car with the new key, starts the car and drives off. Currently the most predominant areas targeted are Essex, London/greater London, Northampton and Birmingham.
See our full demonstration on a Focus RS -
http://youtu.be/dvmSOEKfkug
Our VW AUDI security package
With over 15 years experience, we have specially designed a system no other company in the UK offers which has been tried and tested by us in house. Our specialist canbus modules work by piggy backing onto your cars complex digital electrical system and therefore your VW AUDI warranty is NOT affected.
What makes Secure My Car unique?
We've also designed an OBD port immobiliser which activates only when the Viper alarm is armed. With VW AUDI firmware installed onto the alarm, the Viper system independently immobilises and communicates digitally to the car so you won’t be able to deactivate the Viper system or start the car with your original VW AUDI remote, rendering key cloning or theft of keys void. When disarmed the OBD port is open and free to use for diagnostics which will not affect your vehicles electrics whether factory fitted or after-market.
What sensors does this package include?
Firstly, a dual motion sensor which beeps to ‘warn away’ anyone from the vehicle, covering the all important black spot in your VW AUDI OEM system. Secondly, an impact sensor which activates the alarm if the car is hit in anyway. There is an option to add further sensors which are detailed below.
How does it sound?
Featuring a fully adjustable 1-6 tone cycle siren, the Viper system is much louder than your factory alarm, at a whopping 120db!
Do I receive a separate remote?
We include a 2-way 2000 foot range LED paging key fob. If your system is activated the pager will beep and flash according to which zone has been triggered and will also confirm your commands virtually instantly using the GhostLight™ LED structure. Range can be upgraded to our 1 mile LCD remote if required.
A summary of what’s included -
Viper alarm system inclusive of -
One 2-way Responder LED GhostLight™ 2000 foot range remote
Revenger® 6 tone 120db siren
Dual proximity sensor with ‘warn away’
Dual impact sensor with ‘warn away’
Custom OBD port immobilisation
2nd engine immobiliser
Specialist canbus module with latest Ford firmware installed for full digital control of your car
Trunk pop from Viper remote
Total closure when arming the alarm
Option to upgrade to remote engine start*
*spare key needed if remote start is added.
SmartStart compatible
Fully fitted by our specialist installers to any VW AUDI - £550
Mobile fitting - Can’t make it to us?
Not a problem, we can come to you! We only charge £55 for mobile fitting up to 100 miles from us (Bristol area). For up to 150 miles £65. Any further please email for prices.
Optional extras -
Remote engine start - £150
Glass break sensor - £45
Tilt sensor - £65
Long range LCD remote with 2” screen - £120
The LCD remote displays real time information about your car at all times. If you leave the boot, bonnet or door open for example, the remote will instantly notify as you leave the vehicle.
Viper SmartStart & Smartphone application - £400 plus annual subscription of £99
(See below for package offers)
Installed onto your car, the SmartStart feature allows you to track and control (including a host of other features) your vehicle from anywhere in the world securely via your Smartphone. As the system is connected to your Viper alarm you will receive real time updates and should your alarm be activated, your Smartphone will mimic the sound of the siren through the application. The annual SmartStart service plan can be purchased from us at an additional cost of £99 after installation. Just search for ‘Viper SmartStart’ from your Apple, Blackberry or Android app store and download for free.
See how SmartStart can benefit you by viewing it on our demo car -
http://youtu.be/JI1pepkWRVM
SmartStart package 3 - £899
http://www.securemycar.co.uk/smarstart3.html
SmartStart package 4 - £999
http://www.securemycar.co.uk/smartstart4.html
NEW - Viper SmartStart Bluetooth control - £165
For quicker, instant notifications via your SmartStart app we now offer Bluetooth capability. Please call or email for further details.
NEW - PKE comfort access - £199
Includes a small key fob which you attach to your car keys. As you walk close to or from your vehicle the Viper system senses the fob which unlocks or locks accordingly.
See PKE on a Focus RS -
http://youtu.be/zhUEs1gut0U
And on our demo car -
http://youtu.be/p8lnfv7ROuo
Smart Track insurance approved tracker - £400 OR discounted to £230 if fitted with our Viper alarm. Yearly subscription required.
We also offer OBD port relocation - £35
Viper flashing window logo - £30
Full price list
Ford upgrade package £550
Remote start £150
For the Smartphone packages..
Smartstart package 3 - £899.99
Smartstart package 4 - £999.99
Mobile fitting from £55
Glass break sensor £45
Tilt sensor £65
Flashing viper logo £30
Upgrade LCD remote £120
Smarstart bluetooth £165
PKE £199.99 (extra antenna normally needed for boot area £55)
2nd PKE spare remote
Smarstart GPS iPhone control £400
Annual subscription £99
Smartrack insurance approved tracker £230 - (only when fitted with our viper alarm other wise £400)
OBD port relocation £35
Please note when making your booking we do require a £150 deposit (£250 with any trackers) which can be paid by debit, credit card or bank transfer to secure your allocation. A 2.5% surcharge is applicable to credit card payments. Cancellations can be made up to 4 days prior to your installation date for a full refund of the deposit.
Many thanks
Antony Noto
Secure My Car Ltd
Office 01172440019
Web www.SecureMyCar.co.uk
Email Sales@SecureMyCar.co.uk
FacebookYouTubeWebWebTwitterWeb
How does it sound?
Optional extras -
Tilt sensor - £65
Full price list
Remote start £150
Tilt sensor £65
Many thanks
Antony Noto
Secure My Car Ltd
Office 01172440019
Users browsing this forum: Bing [Bot], Google [Bot] and 187 guests
