Fitting new brake lines
Re: Fitting new brake lines
You should also use an 11mm brake hose spanner. As it provides an even force around the nut.
https://www.amazon.co.uk/Draper-Flare-W ... B00862R5FW
For capping off the ends, get any garage to make you some female and male ends with a bent over copper brake tube and attach the end.
I would advise changing all 4 hoses if you're going braded.
For bleeding start at the furthest calliper away i.e. the rear NS then OS then front NS front and then OS.
You can use Ferrodo DOT 5.1 or ATE Blue for the best performance. But make sure you fully bleed the whole system. The more you pump through the better performance you will get. DO NOT do a half cocked job i.e. a couple of pumps. per calliper. I recently flushed my system twice with DOT 5.1 and now my brakes are really responsive.
Regarding blanking off the sensors, As pule333 suggests, I used a set of old male connectors and soldered the ends. Incidentally, my female connectors where corroded and threw a dashboard error, AUDI sell a replacement set if you have the same problem.
Here's mine done:
Here's mine done:
I'd like to correct this to bleed out all of the air and old fluid you have to use both nipples. Do inside then outside.pule333 wrote:Correct me if I am wrong, but you only use one nipple for the front calipers. No need to use both.
I stand corrected. Planning to do disc, pads, and hoses this Saturday. Will bleed from both. Last time I changed fluid, did only from single nipple and it worked ok. But I guess I'm had no comparison and my hard peddle may not have been as hard as it supposed to be. Thanks mate.weekenny wrote:I'd like to correct this to bleed out all of the air and old fluid you have to use both nipples. Do inside then outside.pule333 wrote:Correct me if I am wrong, but you only use one nipple for the front calipers. No need to use both.
RS4 B7 aka Vinnie
RS4 B7 aka Vinnie
I did both front nipples as when I changed my hoses I lost a lot of fluid from both sides i.e. front NS & OS
Covkiller wrote:I did both front nipples as when I was changed my hoses I lost a lot of fluid from both sides i.e. front NS & OS
Looks like you had the brake calipers refurbed as well covkiller. I am just away to do this, along with the braided lines / fresh fluid. If you dont mind asking whom done your caliper refurb (or maybe you bought new calipers), and do you have any pictures of how this looks on your car? As iwould like to see a set of the calipers in red on a mugello blue
So guys I've got the front disks off and all is going well. I have noticed that the connection for the pad sensor cable is damaged on the car end. The cable is exposed slightly.
This what has been intermittently setting off my wear alarm so needs to fixed. Any ideas on how to fix this?
You can buy a replacement cable with female connector from Audi. They're cheap. You'll have to cut off the existing cable and solder the new one in. Get some shrink insulator from Maplins to seal around the new and old. I have done this to both sides.
From my receipt:
P V1J0 973 702 C3911 Housing £3.16
P V000 979 019 EA C3910 Wire £4.20
Good luck
From my receipt:
Good luck
I'll pm you once I clean my car at the weekendmongo wrote:Covkiller wrote:I did both front nipples as when I was changed my hoses I lost a lot of fluid from both sides i.e. front NS & OS
So after all the threads that I read about bleeding brakes and making sure you don't let the reservoir go dry, guess what happened on the last corner?!?!? Yep, don't ask. Anyway I bled the last of the fluid I had through but my pedal is still really spongy and just goes straight to the floor. I've got more fluid at work so I will bleed again when I get a chance in the next few days. Has anyone got experience with this scenario? Will I be ok just bleeding all corners again or is it likely I will need a Vagcom to bleed the ABS pump?
Hey Jony.jonytek wrote:So after all the threads that I read about bleeding brakes and making sure you don't let the reservoir go dry, guess what happened on the last corner?!?!? Yep, don't ask. Anyway I bled the last of the fluid I had through but my pedal is still really spongy and just goes straight to the floor. I've got more fluid at work so I will bleed again when I get a chance in the next few days. Has anyone got experience with this scenario? Will I be ok just bleeding all corners again or is it likely I will need a VAGCOM to bleed the ABS pump?
Did the reservoir went completely empty? If that's the case, chances are your abs pump needs vagcom bleeding... unlucky mate although it is not a very hard procedure you do need vagcom for this. Since mine is not an original one I am not sure if it would work. Besides never bleed the pump myself but read about it when was planing to replace it on my A4. How much fluid did you run through each calliper? I did around 250ml each corner.
RS4 B7 aka Vinnie
RS4 B7 aka Vinnie
Yeah completely dry, the pressure bleeder wasn't completely vertical so when the fluid got low it let air through and where I work on the car the lights not the greatest so it was difficult to tell the reservoir was low. I do have a feeling the ABS pump needs bleeding. I used just under a litre around the car but as I said it was on the last corner so obviously needs to bled all round again. I have been looking and from what I can see the VDCS lite will let you bleed the ABS pump.
i have the cheapo VCDS lite and it wont com with the b7 at all
i bought a hex one for later models and it seems fine
Users browsing this forum: No registered users and 126 guests
