Page 1 of 2
After market exhaust info please
Posted: Sun Sep 11, 2016 7:51 pm
by Grizwold
Was be looking at getting a miltek in the near future , what I've read
These are the ones to have ?
I've got standard exhaust on my b7 rs4
What are your views is it worth the ££££
In return of what you get ,
& have you got to have a remap ?
Thanks in advance :thumbs:
Re: After market exhaust info please
Posted: Sun Sep 11, 2016 8:00 pm
by MikeFish
You've read wrong my friend. Milltek were the exhausts of choice about 5 years ago. Still the most popular exhaust but the current trend is for either modyfing the standard exhaust or a JC Weldfab. Do a search, there are plenty of threads on this topic already.
Posted: Sun Sep 11, 2016 8:45 pm
by Frostie
I have a Milltek... it's ok but i wouldn't really recommend it... it drones badly under 2000 revs. my brother in law has done a centre box delete on his, and it sounds pretty much perfect.
Posted: Sun Sep 11, 2016 9:09 pm
by Grizwold
Thanks guys , the standard one sounds fine but not on par with
Say amg or jag ???
Don't need no more Bhp just a better sound if that makes sence
Posted: Sun Sep 11, 2016 11:01 pm
by FaisalJ
Modified OEM exhaust (pre-cats deleted, centre resonator replaced with X-pipe, valves stuck open):
https://youtu.be/E-Bm-gmEP6E
Full JC Weldfab system:
https://youtu.be/65SZXj4fTXA
Posted: Mon Sep 12, 2016 1:08 am
by audi_do_dat_den
Save yourself a wedge of money and start off with a centre resonator delete on your standard OEM system.
Sounds like the car should sound.... and your tailpipes will fit the rear end diffuser properly....
Then if you want more noise, gut your pre-cats.
Then if you're not entirely taken and you want to piss your neighbours off/set off car alarms, go and spend a fortune on a JC Weldfab or even go financially mental and have a Capristo fitted.
Posted: Mon Sep 12, 2016 6:03 am
by A20LEE
Milltek is the go too brand of the uneducated modifier.
Posted: Mon Sep 12, 2016 1:59 pm
by rs user
there was a miltek resonated sytem fitted to my rs4 when i bought it-i find it a pretty decent system,well enough made
fits well by the look of it and sounds nice- i bought the non res centre sections in case i fancied a change-but its loud enough for me at my age tbh
if it wasnt already fitted i would have simply left it with a standard system and possibly tried a centre section delete if it was easily changed back-but i dont think it is without a wee bit of work
Posted: Mon Sep 12, 2016 7:12 pm
by ant@apautomotive
Milltek no longer available.
They discontinued the RS4 B7 system last month. A few stockists may have some left.
Posted: Mon Sep 12, 2016 8:22 pm
by Starry
I find it strange that Milltek get such a slagging, I've had several on all sorts of cars and never had a problem. At the moment I'm running a non res valved Milltek with gutted pre cats.
With the flaps open its as loud as you'd want and, yes there is a little drone but you can drive around it. With the flaps closed it still sounds good, nice deep rasp but a fair bit quieter.
Posted: Mon Sep 12, 2016 8:31 pm
by Grizwold
As above any idea on cost for this , seems a shame to ditch
A perfectly good exhaust system if nothing wrong with it when you can get this done ?
Posted: Mon Sep 12, 2016 9:08 pm
by Frostie
Starry wrote:I find it strange that Milltek get such a slagging, I've had several on all sorts of cars and never had a problem. At the moment I'm running a non res valved Milltek with gutted pre cats.
Pretty much the same here.. except i have no cats, but as you say... it is possible to drive it in such a way that you don't hit the "drone" revs. other than that, it is a good system, although if it was down to me to spend £1500 on a Milltek, i think i would spend a bit extra and get the JC exhaust, or if not wanting to spend that sort of money, for the sake of around £80, do the centre box delete.
Posted: Mon Sep 12, 2016 9:41 pm
by MikeFish
Grizwold wrote:Modified OEM exhaust (pre-cats deleted, centre resonator replaced with X-pipe, valves stuck open):
Centre res delete about £100 to £200. Personally I wouldn't bother with x pipe, just go straight through.
Disconnect valves takes about 5mins and costs the price of 2 screws and 2 cable ties.
Gut pre cats is more about extra power than sound. It will add a little bit of sound but only worth doing as a power mod (rather than sound) as it'll be about £600 and will probably require a remap to get right of the error lights (although some people report having no errors).
Posted: Mon Sep 12, 2016 10:58 pm
by FaisalJ
I paid £650 - but that was mostly because I had new downpipes made up, rather than gutting the precats on the existing ones.
From memory, £450 of the total cost was the new downpipes, and the remaining £200 covered the X-pipe (made with flanges so I could put the OEM centre silencer back if needed), and fitting the system (the car went to the exhaust shop without an exhaust after removing an aftermarket system, and the OEM system arrived later).
Posted: Tue Sep 13, 2016 9:43 pm
by SuperNik
Depending on whereabouts you are you could ask rs246 members that are local to you to give you a demo. There's quite a few with the above suggestions spread around.
