A mate from Audi did it, i was not there. All the other faults cleared, ill ask him.jonson66 wrote:As for the fault code not clearing, is this with ignition on and engine off?
Fault code help
Re: Fault code help
Re: Fault code help
Should they all read the same?jonson66 wrote:You might need to go to each vacuum operated component and take vacuum readings from each one and compare your results with what they should be. Maybe you could start with the exhaust flaps and work your way back? It all can be done on vehicle idle I believe. If you have a slightly split hose then your readings will be out. I hope this helps mate
Re: Fault code help
The 2 flaps on the exhaust should definitely read the same. Problem is because I don't own one yet I don't know what else runs off the the vacuum system. I assume the inlet runners do but you had them mapped out? Someone else would need to clarify mate. If the fault can't be reset this usually means there's an electrical circuit fault or issues with the software. There could be a throttle resetting procedure via Vagcom but I'm not sure mate
Re: Fault code help
thanks for your help mate, ill have a play tomorrow and see what happens..jonson66 wrote:The 2 flaps on the exhaust should definitely read the same. Problem is because I don't own one yet I don't know what else runs off the the vacuum system. I assume the inlet runners do but you had them mapped out? Someone else would need to clarify mate. If the fault can't be reset this usually means there's an electrical circuit fault or issues with the software. There could be a throttle resetting procedure via vagcom but I'm not sure mate
Re: Fault code help
Not a problem mate, hope you can sort
Users browsing this forum: delroyx, Google Adsense [Bot] and 525 guests
