VAG Coding for RNS-E removal
Posted: Sat Aug 06, 2016 11:45 am
by vicrex
Hi,
Hoping if anyone can help at all with VAG coding for RNS-E removal, as have swapped the RNS-E from the car and would like to clear errors showing in a scan. Researched through the forum, ross tech wiki and links could find to find the below info.
If anyone has info on coding it out so to remove any error codes it would be greatly appreciated if they could post anything that might confirm below or point me in correct direction. Would like to try and code clear the RNS-E, any related such as Bluetooth module, Nav (BT and Nav by new unit), Immobilizer, etc, updating where needed and removing where needed.
Faults are showing under :
Address 17: Instruments 2 faults
Address 25: Immobilizer 2 faults (seem to be similar to above)
Address 37: Navigation not showing anymore due to RNS-E removed
Address 56: Radio not showing anymore due to RNS-E removed
Address 77: Telephone 2 faults
Details on each of above are:
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 983 C HW: 8E0 920 983 C
Component: KOMBI+WFS 4 H14 0100
Revision: 0100 Serial number: 00000000000000
Coding: 0023418
Shop #: WSC 17455 000 1048576
VCID: 2F6DE244BDB1703A0A-5140
2 Faults Found:
01304 - Radio
004 - No Signal/Communication - Intermittent
01300 - Control Module for Navigation with CD-Rom (J401)
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0023418
2 Faults Found:
01304 - Radio
Assuming as RNS-E is now gone, no possible reply from below Address 37 anymore.
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8E0 035 192 Q HW: 8E0 035 192 Q
Component: RNS-E HIGH EU H73 0550
Revision: 02S Serial number: AUZBZ7G1102620
Coding: 0309713
Shop #: WSC 12345 123 12345
VCID: 326BEB30AE835DAEB8-517A
No fault code found.
Assuming as RNS-E is now gone, no possible reply from below Address 56 anymore.
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0309713
VCID: 326BEB30AE835DAEB8-5198
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 H HW: 8P0 862 335 H
Component: FSE_255x BT H26 0290
Revision: 00000000 Serial number: 00000005076852
Coding: 0010722
Shop #: WSC 06335 000 00000
VCID: 3B75C61479C99C9AB6-5140
1 Fault Found:
01304 - Radio
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 204
Time Indication: 15
Info found to follow below.
Huge thanks in advance for anything you think need to know!!
Victor
Re: VAG Coding for RNS-E removal
Posted: Sat Aug 06, 2016 11:46 am
by vicrex
From researching I think the following may help but am unsure before I try anything:
Coding currently: 0023418
http://wiki.ross-tech.com/wiki/index.ph ... C/8ED/8HE)
From above wiki page:
Update mine from 0023418 to 00xx418 - unsure of this coding for update.
Cant find any entry on http://wiki.ross-tech.com/wiki/index.ph ... et_(8E/8H) for this so unsure but looks same / similar to above Address 17 Instruments.
Coding currently: 0309713 (when it was still in)
http://wiki.ross-tech.com/wiki/index.ph ... em_(RNS-E)
Update mine from 0309[7]1[3] to 0309[1]1[1] to remove Telephone and CD changer/iPod.
However with both above Addresses now not showing - assuming not needed anymore and other coding of Addresses above / below may sort.
Coding currently: 0010722
http://wiki.ross-tech.com/wiki/index.ph ... reparation
Update mine from 0010[7][2][2] -> 0010[5][0][0]
Also notice that there are 2 Telephone related fuses # 5 (shared with oil level, sensor and more) and # 8 just for Telephone.
Any info to help on above or point me in right direction is greatly appreciated.
Again thanks in advance!
Victor
