Water Leak
Water Leak
Hi, after a bit of advice please, discovered this morning a damp patch on the drive on the left hand side of the car just in front of the wheel (RS4 B7). On closer examination, if you look through the vent sections of the front bumper directly in front of the wheel you can see a pipe with what appears to be a metal fitting on the end and it seems to be leaking from there.
What is that pipe going to and is it an easy fix?
Thanks in advance.....
Sprint Blue B7 RS4, Milltek, Resonator Delete, Bilstein Suspension, ITG Panel Filter, Forge Oil Cooler,BBS Alloys, Black Optics, Rear Tints, TRW Track Control Arms, Carbon Clean.
Re: Water Leak
Probably the auxiliary radiator leaking, common issue on the RS4. Some people delete and run a cold air feed in that location instead.
Misano Red RS4 B7 Avant
Re: Water Leak
Thanks, called Unit 20 this morning and they confirmed it is indeed the auxiliary radiator leeking, booked in for a week tomorrow.
Re: Water Leak
Just swap the right rad to the left and get a CAF in therekevconn wrote:Thanks, called Unit 20 this morning and they confirmed it is indeed the auxiliary radiator leeking, booked in for a week tomorrow.
Re: Water Leak
I read somewhere this morning that the CAF can cause overheating problems? Not clued up enough on these cars to fully understand the ins and outs of what might be right or wrong.
In any case the right one might just be as bad as the one that's leaking, won't know until the bumper comes off I suppose.
Re: Water Leak
kevconn wrote:I read somewhere this morning that the CAF can cause overheating problems? Not clued up enough on these cars to fully understand the ins and outs of what might be right or wrong.
I would say a fairly high percentage of guys running B7's on this forum have fitted the CAF at the sacrifice of an aux rad to no detrimental effect, including myself now for over 18 months!!.
You are possibly right in the assumption that the opposing rad may also be corroded too, although the corrosion tends to be caused by foreign objects such as leaves, debris etc getting stuck in them, so one may have seen more crap than the other!!
Like you said though, have a look when the bumper is off and see what's what.
Re: Water Leak
Thanks again. Would anybody have any pics or information of this being done please?
Re: Water Leak
kevconn wrote:Thanks again. Would anybody have any pics or information of this being done please?
Check out the FAQ thread at the top of the page mate. Has a full set of Instructions. Nice easy job and works out a lot cheaper than replacing an aux rad
Re: Water Leak
Users browsing this forum: lugars4 and 235 guests
