Steering wheel whine
Posted: Sun Jun 19, 2016 9:59 pm
by rs4uk
Hi guys
I noticed that on my rs4 if I full lock the steering in either direction I get a whine, does anybody else get this? Is it normal?
Only get the noise on full lock
Re: Steering wheel whine
Posted: Sun Jun 19, 2016 10:02 pm
by Shinobi675
Are you sure it's the steering wheel? I get something very similar and comes from slightly to the left.
I finally realised it was only when the wife was in the passenger seat though.
Posted: Sun Jun 19, 2016 10:06 pm
by MikeFish
Check your power steering fluid level.
Posted: Sun Jun 19, 2016 10:07 pm
by RichieRS
Shinobi675 wrote:Are you sure it's the steering wheel? I get something very similar and comes from slightly to the left.
Haha. Excellent
I presume you've checked your power steering fluid level?. Have had cars in the past that have been noisy on full lock when the fluid is low
Posted: Sun Jun 19, 2016 10:08 pm
by RichieRS
Mike beat me to it
Posted: Mon Jun 20, 2016 2:02 pm
by toyneg
rs4uk wrote:Hi guys
Every RS4 i have heard makes a squeal noise when on full lock, mine certainly does too
Posted: Mon Jun 20, 2016 5:30 pm
by C5ARK_RS4
As Mike said. Check power steering fluid level. Mine was doing it and a very small top up cured the problem.
Posted: Wed Jun 29, 2016 11:27 am
by ewand
You might want to flush the PS fluid too.
viewtopic.php?f=35&t=114100
Posted: Wed Jun 29, 2016 12:19 pm
by audi_do_dat_den
I get a squeal when on full lock against the stops.... it doesnt make any noise at any other time.
Initially i thought it was a belt slipping but since the power steering is directly driven from the PTO gears, ive put it down to an ageing relief valve.
My mates RS4 makes exactly the same noise so im not bothered by it.
Might do a flush but its tickety boo otherwise.
Posted: Thu Jun 30, 2016 3:32 pm
by hector8
This happened me a few weeks back. Was the fluid level. Very small top up needed.
Remember when measuring the level the dip stick is not to be screwed down, just measure when unscrewed. Only takes a second or two of light pour to top up.
Posted: Sat Jul 02, 2016 3:22 pm
by harding
Ive had this for 3 years on my car. Where do i top up the fluid??? Need to try!
Posted: Sat Jul 02, 2016 9:57 pm
by MikeFish
harding wrote:Ive had this for 3 years on my car. Where do i top up the fluid??? Need to try!
The Power steering fluid reservoir is on the right hand side of the engine bay in front of the windscreen washer resevoir. There is a cut out for it in the plastic engine cover.
Posted: Sun Jul 03, 2016 11:33 am
by harding
MikeFish wrote:harding wrote:Ive had this for 3 years on my car. Where do i top up the fluid??? Need to try!
Thanks Mike!
And how much should i put in there? Will stop by audi in a bit and get some.
