Jit's RS4 OEM Plus build
Re: Jit's RS4 OEM Plus build
Hi All,
Only a few updates, had the brake calipers painted red, can't believe how big the front brakes are! In black very understated.
The best mod so far, middle box delete and x pipe installed can not believe how much better it sounds!! Lovely burble and some rasp at the top end of the Rev range highly recommend this.
Having the clutch done tomorrow by CAMSPEC.
Jit
2016 RS3 8V
2007 RS4 B7 Cabriolet Gone
2016 RS3 8V
Brakes look good, as you said, black really doesn't do them justice..
Looks really good . who did your brakes for you and how much and the exhaust ? Pm if you prefer
Very sharp, and like the red calipers. You might want to consider the RS caliper plate for the rear which makes a huge esthetic difference. On this side, ECS sells it under RS7 parts for example.
Harris. wrote:Looks really good . who did your brakes for you and how much and the exhaust ? Pm if you prefer
Thanks!
Exhaust was done by EMP Performance and it was £250 all in. I am really loving this mod! She sounds amazing!
http://www.empperformance.com
The calipers were done by Specialist Tyres, a guy called Faz runs the place, I supplied the decal, the finish is really good, all 4 calipers done for £250 all in.
http://www.specialisttyres.co.uk
Cheers.
Jit
2016 RS3 8V
2016 RS3 8V
Thanks mate.Starry wrote:Brakes look good, as you said, black really doesn't do them justice..
Jit
2016 RS3 8V
2016 RS3 8V
Thank you mate, I did think about them, just not keen on drilling holes in the calipers! They do look good though.Seattle-squash wrote:Very sharp, and like the red calipers. You might want to consider the RS caliper plate for the rear which makes a huge esthetic difference. On this side, ECS sells it under RS7 parts for example.
Jit
2016 RS3 8V
2016 RS3 8V
Hi Jit,
Did you have the clutch done?
I have exactly the problem you've described and I've had the pipe changed. All I got was a heavier clutch pedal and the slow return after heavy acceleration is still there!
I can't for the life of me find any one around or on the internet that actually knows how to cure this issue.
I hope you have solved it and can let me know the answer. Cheers Buddy.
I'm more of an Avant man but yours looks nice
Sprint Blue B7 RS4 Avant, new clutch, DMF, a Milltek, carbon clean, new front shocks.
Last car, B5 S4 Avant, Milltek, Stage 1.
I did have it done, it's so much better know it won't stick down after you've it the beans!!
had the following done :
Clutch
Release bearing
Pressure plate
DMF
Slave cylinder
Master cylinder
Rob's braided updated pipe.
Problem solved, I got the LuK clutch kit, Sachs master and slave cylinder when Euro's have the 30% off deal they were less than £160 all in DMF is expensive and the labour!
Hope you get it sorted soon!
Jit.
Clutch
Release bearing
Pressure plate
DMF
Slave cylinder
Master cylinder
Jit.
Jit
2016 RS3 8V
2016 RS3 8V
Did you get a teflon lined, braided clutch pipe or a standard Audi pipe?AviatorEGHH wrote:Hi Jit,
I got the updated Audi pipe. I'm hoping the new one is ok considering the bad one took 65,000 miles to deteriorate.
I have a feeling there is more to it than just the pipe. There are too many unusual symptoms. Varying bite point after heavy acceleration, jumpy pull away when the car is cold, immediate bite after heavy acceleration (not nice and gradual). It's all too weird.
Exhaust looks good. Any video clips?
Video clip would be good!!
No sorry not got any sound clips, but will try and get some.
Recent updates, I had the chrome vinyl wrapped as the chrome has always bothered me.
Rear lights also tinted
Front headlights also tinted but wasn't keen after these pics have removed the film
Jit
2016 RS3 8V
2016 RS3 8V
Looks lovely. I assume optics wasn't available on a cab? Always thought one would look good with black.
Users browsing this forum: Bing [Bot] and 151 guests
