Well, had the car 8 weeks now and loving it but it's costing me a fortune. I've had the wheels powdercoated Gloss black first of all:
Then after a oil change service i found out that there was a fault on the inlet manifold flaps so got in touch with Unit 20 and had that done yesterday, turned out to be the arms had worn that operate the flaps, not a cheap job but at least i know the cars right:
Now i find out that the oil cooler pipes are starting to seep oil ever so slightly so rather than go for an OEM cooler/pipes i've decided to have the upgraded Forge oil cooler fitted in a coople of weeks. Hopefully thats it
Massive thanks to Unit 20 too, quality service
8 Weeks In......
8 Weeks In......
Sprint Blue B7 RS4, Milltek, Resonator Delete, Bilstein Suspension, ITG Panel Filter, Forge Oil Cooler,BBS Alloys, Black Optics, Rear Tints, TRW Track Control Arms, Carbon Clean.
Re: 8 Weeks In......
Did you have the flaps removed, or replaced ? Not normally a fan of black wheels, but those look pretty special against the blue.
2007 black RS4 saloon. Bilstein Coilovers, MRC Re-map, Miltek non resonated valved exhaust with de-cats, Gruppe-M carbon induction, JHM manifold spacers, Stage 2 manifold, cold air feed.
Some would argue that the Forge cooler pipes aren't exactly an upgrade either!
What were the symptoms of the dodgy flaps?
Current: 07' B7 RS4 Avant
Previous: Mk2 Golf VR6 conversion, Mk2 Golf GTi 16v, Mk2 Golf 1.6 GL Auto, Mk3 Golf R32 conversion, BMW Z4 Coupe, BMW 430d, Audi S3, Defender 90 XS, Alfa Romeo 145
I hope you got a carbon clean why they had the car apart.
No mate, kept the flaps that's why i needed new flap arms.Frostie wrote:Did you have the flaps removed, or replaced ? Not normally a fan of black wheels, but those look pretty special against the blue.
No symptoms other than it showing up on the ecu data that they were stuck open and it turned out to be worn arms. Would imagine that the forge cooler and pipes will be good for another 80k miles, it's peace of mind coz these are starting to weep.ChrisW wrote:Some would argue that the Forge cooler pipes aren't exactly an upgrade either!
No i didn't bother, that would have been another days labour and it wasnt bad enough to warrant it, would have been back to normal in 6 months anyway from what i've read and been tolddocurley wrote:I hope you got a carbon clean why they had the car apart.
Users browsing this forum: MTBear and 493 guests
