bilstein B16 coilovers b7 RS4 cab
can anyone tell me whats missing in this picture look carefully at the top of spring
Re: bilstein B16 coilovers b7 RS4 cab
yep spot on....bam bam you been on here a while how important is that rubber
Very. Top mounts should be replaced every 5-6 years / 60,000 - 80,000 miles. Having fuct topmounts would make for some pretty sloppy suspension. Can't imagine the tracking or tyre wear would be fantastic either.
hahahaha yep your right again now for the pricks that fitted the kit and it was only pointed out to me when kim collins did a clutch and flywheel change and a health check a good seven or more months down the line .......culprits are AMD ESSEX
m5killer wrote:...AMD ESSEX
looooooooooooool
I've had trouble with them in the past, and wondered if maybe they'd improved...I guess not!m5killer wrote:hahahaha yep your right again now for the pricks that fitted the kit and it was only pointed out to me when kim collins did a clutch and flywheel change and a health check a good seven or more months down the line .......culprits are AMD ESSEX
2007 RS4 B7 Avant
The list continues to grow of poor work and unhappy customers......FaisalJ wrote:I've had trouble with them in the past, and wondered if maybe they'd improved...I guess not!m5killer wrote:hahahaha yep your right again now for the pricks that fitted the kit and it was only pointed out to me when kim collins did a clutch and flywheel change and a health check a good seven or more months down the line .......culprits are AMD ESSEX
Sprint Blue B7 RS4 - Black/Titanium optics, Anthracite OEM 19's, De-resonated OEM Exhaust, TTRS FBSW, MRC Stage 2 De-flapped manifold, Full Carbon Clean, MRC Stage 2 Re-map, 431.5 BHP...... must...not...spend....more...
Had a think about it, and saw AMD's google rating, and decided to leave a google review.
Hopefully others will see it when they search for AMD Essex online and it will save them some grief!
2007 RS4 B7 Avant
- Surrey Sam
You mean, coil spring rubber isolator?bam_bam wrote:Top mount rubber?
Bullied at school much, Sam?Surrey Sam wrote:You mean, coil spring rubber isolator?bam_bam wrote:Top mount rubber?
- Surrey Sam
Nope.bam_bam wrote:Bullied at school much, Sam?Surrey Sam wrote:You mean, coil spring rubber isolator?bam_bam wrote:Top mount rubber?
I was conscious of the fact; that there is always bigger fish in the pond than yourself.
What? The big guys, they weren't the ones everyone worried about. It was their smaller smart-mouthed mates they'd send in to cause trouble.
Anyways, it was a pretty geeky thing to say, Sam. Just checking for your inner nerd.
hahahahaha pmsfl
Users browsing this forum: Bing [Bot] and 235 guests
