Any idea what the thread size is? Something like this?
'http://www.ebay.co.uk/itm/FORD-FOCUS-ST ... 0832076616
L/s engine mount /bolt for anti roll bar clamp ...help
Re: L/s engine mount /bolt for anti roll bar clamp ...help
Bloody hell fire £65
It's worth a punt at £2.38 off flee bay or speak with Ben at MRC as they may have a spare knocking around.
Good luck
Good luck
Can you provide specs? length (from the bottom of the flange to the end of the threads), diameter, thread pitch to start?
http://www.mcmaster.com/# has always been my go-to for unusual fasteners on this side of the water. Maybe send them an email and see if they will ship Over There?
Best of luck.
Best of luck.
B7 RS4 Sedan, Phantom Black Pearl
Valved non-resonated Milltek with 200-cell DPs, and JHM tune, 10mm spacers
B8.5 Allroad, Monsoon Grey
CPO, stock
Former Quattros
B5 S4 Sedan, C4 S6 Avant, Type 89 Coupe Quattro, Type 44 Quattro Sedan
CPO, stock
Former Quattros
The split ring washer and m8 bolt and nut worked a treat.getting the original splined bolt in ...closest to front of car was a bastard !! No access. Ended up getting the earth out of a 2.5mm electrical cable, putting solder on end and making flat, then superglued to the bolt....was a pain to say the least. All on and working..... on to the next issue......aux belt tensioner blew up and new belt shredded lol
RS4 B7 Saloon, Phantom Black , Billy B14 and ss+ arbs, LED's all inside & out with Dectane LED tailights. deflap, MRC Stage 2, Carbon Clean, no pre-cats, Custom Blueflame non res cat back exhaust, AP Racing Discs, alcantara wheel, gaiter and handbrake retrim, R8 gearknob, red belts (anyone want to swap belts for black ;-/ ) 438PS
Are you sure the anti roll bar bracket bolt only comes as part of the engine monut assembly? The engine mount assembly is anout £250. And while it makes it easier to change the engine mount if you take the ARB off, I'd be amazed if you could only get the bolt for the ARB mount by buying the engine mount.
Glad you got it sorted though.
100 percent yes. You cannot get those bolts at audi. Look at the etka
Users browsing this forum: Google Adsense [Bot] and 274 guests
