Front suspension overhaul DIY or not?
Posted: Tue Mar 01, 2016 8:42 pm
by audi_do_dat_den
Hello folks,
Im going to overhaul the front suspension links and bushes etc, but is this possible to do yourself or are there special tools required?
I will change out for a Meyle HD kit in the coming weeks hopefully.
Re: Front suspension overhaul DIY or not?
Posted: Thu Mar 03, 2016 12:57 pm
by audi_do_dat_den
Hmmm.... i guess thats a 'not' then....
Posted: Thu Mar 03, 2016 8:35 pm
by Harris.
I did mine myself. Hardest part Is getting the old parts off
Posted: Thu Mar 03, 2016 11:46 pm
by esp_mm-270
Not a problem if you can get the upper control arm pinch bolt out. They tend to resist removal
Posted: Fri Mar 04, 2016 1:36 am
by PaulT
Yep the upper arm pinch bolts are known to seize. I had all upper, lower arms and arb links replaced recently - one side was seized solid and would not shift even using blow torch, ended up with one new upright.
Posted: Fri Mar 04, 2016 10:08 am
by Audi Pardner
Agree on the pinch bolts. Mine were a real struggle when I fitted the adjustable spring kit. I doubt they would have come free without a lot of heat, Wurst Rost Off and a 4 post lift. I wouldn't try it at home personally.
Posted: Fri Mar 11, 2016 12:16 pm
by rogc
Hi all, where are you sourcing your parts from? TPS? I found a complete Meyle HD kit of bushes and arms but never heard of them! :/
