Fitting a KW adjustable spring kit
Audi Pardner
Re: Fitting a KW adjustable spring kit
Post by Audi Pardner » Sun Jan 31, 2016 7:31 pm
#1Rs4 wrote:My configuration ground to arch ... is fronts 64.5 cm 8mm h&R spacer
Rears 65cm 10 MM h&R spacer
Tyres. Michelin pss 255/35r19 , i do have to take care over speed humps ect
but overall no headaches :blackrs4:
:thumbs:
I've got a new set of Michelin PSSs to put on the original rims (glad to see the back of the Pirellis it came with) and am going to replace the Contis on the Rotors with Michelins.
Post by MikeFish » Sun Jan 31, 2016 9:36 pm
My rear is about 610mm though.
Rs4.
Post by Rs4. » Mon Feb 01, 2016 9:11 pm
610 is prity low ! that would look good :thumbs:
Rs4 phantom black b7 avant : Mrc tuned
Audi Pardner
Post by Audi Pardner » Mon Feb 01, 2016 9:12 pm
Quick update. Pic of the car with the standard wheels and the kit fitted
http://imageshack.com/a/img921/3980/hsQZ7R.jpg
And one with the Rotors on
http://imageshack.com/a/img921/2525/KHOJdL.jpg
The spokes on the first front Rotor I fitted were within a fag paper of the brake caliper. Looked far too close so I fitted the spacer. Tested the car up the road but the n/s front tyre scuffed on even slight bumps. I don't want to risk the spokes so close to the caliper so I'll raise the ride height tomorrow by 5mm or so and see what it's like.
Fatneck73
Post by Fatneck73 » Mon Feb 01, 2016 9:16 pm
I love this...spesh with rotors. Nice.
jaysrs4
Post by jaysrs4 » Mon Feb 01, 2016 9:19 pm
Sweet :thumbs:
Post by MikeFish » Mon Feb 01, 2016 11:13 pm
I've had the rotors on mine for 2 or 3 years now with no issues. Yes its bloody close to the caliper but its never touched it.
Audi Pardner
Post by Audi Pardner » Tue Feb 02, 2016 9:35 am
MikeFish wrote:I've had the rotors on mine for 2 or 3 years now with no issues. Yes its bloody close to the caliper but its never touched it.
Assume you're not running spacers with the rotors? It just looked so close on mine without a spacer (even though the rim obviously wouldn't flex to cause interference with the caliper when under lateral load :D )
Post by MikeFish » Tue Feb 02, 2016 10:01 am
No spacers for me, it looked like it was going to touch but it actually has just enough room to clear it.
ChrisW
Post by ChrisW » Tue Feb 02, 2016 1:37 pm
Im running a KW kit like this wound to the bottom front and rear. Ive recently taken my 20" speedlines and put on the standard wheels and now I'm getting some scrubbing when cornering hard or hitting a dip at speed, whats this bolt that people are talking about that needs removing?
:bash:
Current: 07' B7 RS4 Avant
Previous: Mk2 Golf VR6 conversion, Mk2 Golf GTi 16v, Mk2 Golf 1.6 GL Auto, Mk3 Golf R32 conversion, BMW Z4 Coupe, BMW 430d, Audi S3, Defender 90 XS, Alfa Romeo 145
Audi Pardner
Post by Audi Pardner » Tue Feb 02, 2016 3:20 pm
ChrisW wrote:Im running a KW kit like this wound to the bottom front and rear. Ive recently taken my 20" speedlines and put on the standard wheels and now I'm getting some scrubbing when cornering hard or hitting a dip at speed, whats this bolt that people are talking about that needs removing?
:bash:
If it's the bolt that #1Rs4 mentions above, it's located inside the top of the front wheel arch and secures the arch liner.
It may be that the offset on your Speedlines is different to the standard rim, hence the scuffing.
ChrisW
Post by ChrisW » Fri Feb 05, 2016 11:20 am
Can it come out without causing any issues, i.e the arch liner isn't going to fall out I take it?
Ozzyz
Post by Ozzyz » Fri Feb 05, 2016 11:31 am
ChrisW wrote:Can it come out without causing any issues, i.e the arch liner isn't going to fall out I take it?
No its fine to remove the screw, i took mine out a couple of weeks ago and have had no issues since, arch liner is still secured in place well even with that screw removed.
Post by MikeFish » Fri Feb 05, 2016 8:36 pm
Yes, mine has been out for years.
Users browsing this forum: DavidRS4 and 140 guests
