ESP Light & Engine Light on. New MAF?
Posted: Sat Dec 12, 2015 1:47 pm
Hi All,
Wondering if anyone if able to help with an issue my car picked up yesterday.
Put my foot down coming off a round about when the ESP light came on and stayed on solid. Came up to a set of lights and it went off but came back on again when I pulled off.
After turning the car on and off again ESP was still on and also the engine light came on (both solid)
Got home and ran a scan with the below results. I've reset the codes but the ESP comes back again after around 30 seconds or when making a sharp turn. Engine light seems to come back on when turning the car on and off a few times.
I'm guessing a new MAF sensor but I've also seen online people talking about an ABS wheel sensor that could also be the issue? How easy are these to fit?
Car has been running fine and is still running ok now even with the errors on the dash.
Ill order a new MAF from TPS on Monday but anyone think it could be anything else?
1 Fault Found:
000257 - Mass Air Flow Sensor (G70)
P0101 - 004 - Implausible Signal
Freeze Frame:
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 54184 km
Time Indication: 0
Freeze Frame:
RPM: 1768 /min
Load: 31.0 %
Speed: 14.0 km/h
Temperature: 83.0°C
Temperature: 46.0°C
Absolute Pres.: 1020.0 mbar
Voltage: 13.462 V
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 G HW: 8E0 614 517 BD
Component: ESP8 quattro H06 0150
Revision: 00000000 Serial number: 00000000000000
Coding: 0004533
Shop #: WSC 06335 000 00000
VCID: 2B55DDB28A8EC366D3-807E
1 Fault Found:
18265 - Load Signal
P1857 - 000 - Error Message from ECU
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x1EC0
Hex Value: 0x4006
Hex Value: 0x0028
Hex Value: 0x01A7
Hex Value: 0x0001
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 54184 km
Time Indication: 0
Freeze Frame:
RPM: 1768 /min
Load: 31.0 %
Speed: 14.0 km/h
Temperature: 83.0°C
Temperature: 46.0°C
Voltage: 13.462 V
Coding: 0004533
1 Fault Found:
18265 - Load Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x1EC0
Hex Value: 0x4006
Hex Value: 0x0028
Hex Value: 0x01A7
Hex Value: 0x0001
