Is this a sign I need a clutch?
Posted: Tue Nov 03, 2015 6:26 pm
I need some assistance as I believe I may need to replace the clutch in the not too distant future. The clutch pedal feels fine and there is no juddering taking up drive, no slipping under power and I don't have any issues with the pedal sticking to the floor. However, it is difficult to engage first and it feels like the clutch is not fully engaging at times because I can feel the car jump forward very slightly when I select 1st.
The car is a 2006 Avant with 78k miles and appears to be the original clutch. However, I would like some expert forum opinion before such a big expense. If it does need a clutch, I will do everything at the same time so can someone help by listing all OEM part numbers for everything I will need (clutch, dual mass flywheel, slave cylinder, master cylinder, hydraulic return pipe etc). Or at least confirm a full list of everything I should change whilst doing the clutch.
Many thanks in advance
