Headlights
Re: Headlights
Ok so I've been in touch with Trups and he is keeping me right with what mods to go for.
However on my run home tonight the headlights decided to start hunting up and down while driving.
The fault buzzer sounded and the fault symbol appeared on the dash. Anyone got any ideas what the issue is here? Your help is much appreciated.
RS4 B7 Saloon Sprint Blue, Bilstein B14 Coilovers, Milltek Cat Back resonated non valved. Spacers 8mm F and 10mm R. Headlight clear zenon lens upgrade with 5500k bulbs plus indicator orange lens delete.
Re: Headlights
I would guess the active leveler have a fault.
Re: Headlights
Hi docurleydocurley wrote:I would guess the active leveler have a fault.
Can the levellers be bought separate do you know or are they part of the headlight?
Don't fancy buying a new set of headlights as I would probably have a heart attack at the price.
Re: Headlights
It would be part of the whole unit but I may have what you need has I have a box of headlight parts and I'm sure at least one has the motor.
Re: Headlights
They made just need readaption you need to plug into to VCDS and get fault code
Re: Headlights
Thanks docurley I'll keep you posted as I am heading to the garage tomorrow so I'll get it checked out.docurley wrote:It would be part of the whole unit but I may have what you need has I have a box of headlight parts and I'm sure at least one has the motor.
It'll be plugged in tomorrow so I'll get back with an update and keep you posted.davers6 wrote:They made just need readaption you need to plug into to vcds and get fault code
Re: Headlights
Ok so had the car plugged in today and scanned. Came back with a fault on the lever sensor.
Where abouts is the lever sensor located? Would like to have a look before I go buying a new sensor.The car has just been in the garage for the timing chain replacement so I would imagine that this sensor would have been disturbed at some point.
There's always something.
Re: Headlights
Almost certainly the level sensor its on the near side front lower suspension arm they probably forgot to unplug it when engine removed or plug it back in when refitted
Re: Headlights
Cheers Dave. It's def plugged in as it's an intermittent fault. I'll have a look over the weekend and see what's going on.davers6 wrote:Almost certainly the level sensor its on the near side front lower suspension arm they probably forgot to unplug it when engine removed or plug it back in when refitted
Re: Headlights
Won't be fully burned in yet as probably 20 hours on them but I hope this helps.marc1 wrote:^ MB2 get a picture up as per FaisalJ's post above.
Users browsing this forum: highrise and 247 guests
