Adaptive Headlight Fault
Posted: Mon Sep 14, 2015 9:32 am
by Donovan
Just bought a B7 RS4 (06) and am thoughrouly impressed with the car overall, however there are one or two issues, the main being this adaptive headlight fault I'm getting.
So far the fault has been totally intermittent and I can't seem to replicate it through operation of the light controls etc. When the fault occurs a yellow headlamp symbol flashes in the top section of the information screen behind the wheel and both the headlights and the wipers stop working until the fault clears (approx 10 sec).
Anyone else experienced this or anything similar?
Don
Re: Adaptive Headlight Fault
Posted: Mon Sep 14, 2015 11:26 am
by neilparf
Welcome and
FON.
Really, you'll need
VCDS/
Vagcom (or someone who does) to run a check really. After that, it could be one of or a combination of, bulbs, ballast, auto levelling sensor or it may just need any error codes clearing with
Vagcom and see if it continues to persist. I suspect it is an error with the above as it re-occurs.
A bit more detail:
http://nickscarblog.com/diy/how-to-fix- ... on-an-audi
My bet would be a failing ballast.
VCDS/
Vagcom is you friend and indeed is the search box on this site...
Good luck.
Posted: Mon Sep 14, 2015 11:37 am
by MB2
Mine did this before - unfortunately before I bought it so I don't know what Reading Audi did to fix it. If it is an adaptive headlight fault it shows up as a different warning symbol to bulbs etc. - it may be worth logging in via VCDS and "adjusting" the headlights to see if that resolves it.
Here is the error light if is the adaptive light rather than the bulb -
Posted: Mon Sep 14, 2015 4:52 pm
by Rw@@dy
I've got that error light but mine is because the lights have been set into tourist mode in
Vagcom as I recently went to Belgium
Posted: Mon Sep 14, 2015 5:39 pm
by neilparf
MB2's is Dynamic headlight range fault - really need
Vagcom
Posted: Mon Sep 14, 2015 6:49 pm
by Donovan
Appreciate the rapid and insightful responses fellas. The fault symbol looked very similar to the one in MB2's image from what I can recall but I'm not positive it was. I'll try to get hold of a VAG-COM and in the mean time attempt to recreate the fault and take note of which symbol it was exactly.
Posted: Mon Sep 14, 2015 7:51 pm
by neilparf
Donovan wrote:Appreciate the rapid and insightful responses fellas. The fault symbol looked very similar to the one in MB2's image from what I can recall but I'm not positive it was. I'll try to get hold of a VAG-COM and in the mean time attempt to recreate the fault and take note of which symbol it was exactly.
Put a post out to see if anyone is close to you with VAG-COM... I helped a few forum members with a few re-codes with mine recently...
Posted: Mon Sep 14, 2015 8:19 pm
by Donovan
I've just gone and bought one from a website called Gendan. I figured this won't be the only time I'll need it and I'd ideally like to be able to fix this issue and any future issues myself with a little expert knowledge from you forum veterans
Posted: Mon Sep 14, 2015 10:15 pm
by neilparf
Donovan wrote:I've just gone and bought one from a website called Gendan. I figured this won't be the only time I'll need it and I'd ideally like to be able to fix this issue and any future issues myself with a little expert knowledge from you forum veterans
Nice one - I purchased mine from Gendan.
VagCom is invaluable! I used it for a bunch of stuff to diagnose and tweak adaptions
Posted: Mon Sep 14, 2015 10:42 pm
by Rick_RS4
Posted: Tue Sep 15, 2015 12:57 pm
by Donovan
Yeah thanks for that Rick, neilparf posted the same link and I has a look through. I figured that eventually I'd get a diagnostics tool and if that aids me in diagnosing the fault or component then I'll try that first before blindly throwing cash and parts at it until it's fixed.
Posted: Wed Sep 16, 2015 8:59 pm
by Donovan
Bit of an update, my
VCDS came!
But with it comes a <beep> storm of incomprehensible garble, at least that's what I've come to accept it as. I ran the auto-scan feature after selecting the chassis and lo and behold there's war and peace in a text file full of errors. Most of it seems to be centered around an intermittent control module fault, but other than that I can't really make heads or tails of it.
I'm not sure how much sense it will make to anyone here but I've dumped it into a pastebin anyway for the time being:
http://pastebin.com/PndYecAB
I didn't expect using the
VCDS effectively would be a walk in the park but it seems I have a lot more research to do before it's much use to me
Posted: Wed Sep 16, 2015 11:10 pm
by Rick_RS4
did you clear it all then scan it again?
most of that is probably a low/flat battery
Posted: Wed Sep 16, 2015 11:16 pm
by Donovan
No, I didn't. I'll give that a try tomorrow. I was considering clearing them. It thought there may be some useful info in there. I have it printed out now either way and will try clearing and rescanning in the morning. Cheers!
Posted: Wed Sep 16, 2015 11:40 pm
by Rick_RS4
that could be ages old, might have to give it a 5 min blast to check everything, and really ignition needs to go on and off 3 times to log any serious code
