Group A: '002 Group B: '004
Engine Speed Engine Load Injection Timing Mass Air Flow Coolant Intake Air
TIME (G28) (G70) Temperature (G62) Temperature (G42)
STAMP /min % ms g/s °C °C
0.04 1760 19.5 1.02 9.33 93 24
0.43 1880 78.2 3.83 35.28 93 24
0.82 2080 77.4 2.81 37.81 93 24
1.2 2280 79.7 3.06 41.33 93 24
1.59 2520 82 3.06 46.44 93 24
1.97 2760 83.5 3.06 52.94 93 24
2.36 3000 83.5 3.31 57.94 93 24
2.74 3240 85 3.31 61.25 93 24
3.13 3480 85 3.31 65.56 93 24
3.52 3720 85.7 3.31 73.92 93 24
3.91 4000 84.2 3.06 76.19 93 23
4.29 4200 83.5 3.06 77.58 93 23
4.67 4440 82.7 3.06 86.58 93 23
5.07 4640 84.2 3.06 90.28 93 23
5.46 4880 85 2.81 89.64 93 23
5.83 5120 85 2.81 102.97 93 23
6.22 5360 87.2 2.81 105.17 93 22
6.61 5600 93.2 3.06 124.92 93 22
7 5840 93.2 3.06 122.56 93 22
7.38 6040 92.5 2.81 128.28 93 21
7.77 6280 91.7 2.81 131.97 93 21
8.16 6520 91.7 2.81 136.42 93 21
8.55 6720 91 2.81 144.75 93 21
8.92 6920 90.2 2.81 142.42 93 21
9.31 7160 89.5 2.81 144.42 93 21
9.7 7360 88.7 2.81 151.06 93 21
10.1 7560 88 2.81 145.31 93 21
10.4 7720 88 2.81 147.03 93 21
10.8 7880 86.5 2.81 159.06 93 21
Does this look like a healthy RS4? Stock apart from Caf and K&N panel filter.
Maf readings
Re: Maf readings
If you have a browse through the thread Rick put up earlier it looks like you could be somewhere around 400bhp based on Ricks first post which was at 160g/s per bank
viewtopic.php?f=35&t=93156&hilit=what+m ... ou+reached
Re: Maf readings
Yep, im getting 320 both banks easily but I'm modified and no carbon clean. I've hit high 340s before.
The man maths is that the sum of both banks i.e 1 bank doubled equals about 80% of Max power so as stated above, a combined Maf of 320 is equal to approx 400bhp.
Re: Maf readings
That's not too bad then. It's got the engine management light up still something to do with cooling fan which Rick_RS4 reckons it's the module and one about the secondary air pump having insufficient flow?
I'll have to get manifold off and see if it needs carbon cleaning.
Re: Maf readings
Unless it has been carbon cleaned in the last few months it will 'need' carbon cleaning.
Re: Maf readings
FYI, 160g/s is a pretty good reading for your car given the mods you described assuming it hasn't just been cleaned.
Re: Maf readings
I don't think it's been cleaned, I've only just bought it so not 100%. Noticed a difference after fitting the caf mod.
Re: Maf readings
It hasn't been carbon cleaned, done 41000 miles.
