How-to guide. Fix your leaking / deflating bolsters!!
Posted: Sun Aug 09, 2015 5:22 pm
The leaking side bolsters on my B7 RS4 have been annoying me for years.
It was fixed under warranty 3 years ago, but after a year it was leaking again.
Today i decided to tackle it. It wasn't as hard as i feared to get to the valves and i was pleased to find the problem and cure it for a few quid!! Much better than spending £160 per valve !!
First remove the recaro seatbelt loops, item 10 in the image. They are retained by tabs on item 8. I did it from the back seat of the car, gently levering item 10 up and away from item 8. Its common to break the tabs on item 8 doing this, as Audi did when they replaced my valves some years ago!!
So i am purchasing new item 8's. Next, release the leather. It pulls out of the retaining grooved in the backrest as shown. Releasing the leather all the way around the backrest, the seat cover can pivot forward. (I left the leather attached at the base). The lumbar pad is removed in this image, exposing the valves. The left valve (Item 7) controls the side bolsters. The right valve (also item 7) controls the Lumbar. To remove the valve, disconnect the connector and carefully pull the hoses off, noting their locations for re-fitting! After hours of investigation and leak tracing, i found this crack. (Circled red). (Don't remove the brass insert, it is not necessary.)
The crack is most likely caused by the the brass insert being too large and splitting the plastic housing open over time.
To fix, fill the cavity behind the crack and around the base of the brass insert with a 2-part Araldite or a similar hard setting glue. (in this pic i have the valve apart, this is not necessary) What i found interesting is that i had one leaking valve and one good. The leaking valve is stamped 2005 manufacture. The good valve is 2009. Maybe they improved it? When i re-assembled it, i noticed the lumbar pad plastic retaining screws that go into the white foam had worm the hole in the foam out, allowing the lumbar pad to slip down.
I re-filled the holes with expanding foam, should give it a few more years life. Hope this helps someone.
