Satnav
- Silverfox42
Re: Satnav
It should happen automatically when you 'start' your destination.
I assume you have the RNSE head unit and it has been coded in correctly?
2017 RS6 Performance
Previous:
2006 RS4 B7 Cab, 2014 RS4 - Suzuka + a ton of toys, 2011 RS5, spec'd up + ABT exhaust, 2006 B7 RS4 'loon - 5 years of fun! 2006 Aston V8 Vantage, 2006 S4 Cab, 2005 S4 Avant, 2000 TT 225 Cab, 2001 2.5 A4 TDI Quattro, 2000 A4 1.8T Sport, 1996 2.6 80 Cab, 1997 A4 1.8 T Sport
Previous:
Re: Satnav
Yeah got the RNSE head unit. It doesn't happen automatically. How do you code it in? Not sure as I've not long had it. Thanks
Re: Satnav
Weird question really as it "just works" normally; was the Satnav fitted from new (factory) or has someone swapped the system over later?
There is normally a way to change what exactly appears in the DIS, just not sure which stalk/button/option you need to press to change it on a B7, though I think it will return to default at startup.
Re: Satnav
Not 100% sure if it's been in from new. Satnav all works except the drivers info screen, it just made me think when my mate said about it.
Re: Satnav
It's been a while since I took my RNS-E out, but do you lose the sat nav display if you have any errors on the DIS? I seem to recall any errors would replace the music info like radio station / track name etc right at the top of the DIS but not the sat nav info in the middle but worth mentioning in case my I have forgotten.JmRS4 wrote:Not 100% sure if it's been in from new. Satnav all works except the drivers info screen, it just made me think when my mate said about it.
- RossDagley
- Top Gear
Re: Satnav
What firmware is on the RNSE?
I'm presuming the RNSE turns off when you take the key out the car and lock etc? Does it have the correct RS4 boot logo?
Press NAV, then press SETUP, then scroll down to the "Compass" option and press the large knob to place a tick in the "Compass" box. You should now see the centre part of your DIS showing something like ">N<". That should prove if the RNSE is coded for the DIS.
Next, select a destination, click on "Start Navigation". On the RNSE screen you should see a map with an active route (blue roads). Then turn the RNSE off and back on. You should now see navigation information in the centre part of your DIS.
If you don't, it's likely a coding or firmware issue.
Previously:
Previously:
Re: Satnav
The RS4 boot screen is not standard and will only show if it has been added by a previous owner.
- RossDagley
- Top Gear
Re: Satnav
Weird as mine had it - must have been vagcommed previously then I guess. I know I had to do it on the replacement RNSE I installed as it was out of a poverty spec A4.MikeFish wrote:The RS4 boot screen is not standard and will only show if it has been added by a previous owner.
Carry on!
Previously:
Previously:
Re: Satnav
Only if that's a pre 2010 RNSE - the OEM RNSE in the RS4 will indeed show an RS4 logo via Vagcom. The Updated 2010+ RNSE is only the Audi MMI logoMikeFish wrote:The RS4 boot screen is not standard and will only show if it has been added by a previous owner.
Channel 018: Start Screen
The start screen setting has to correspond with the control module coding, e.g. a S3 start screen doesn't work with an A4 coding.
0 = Standard Start Screen
1 = Audi S3 Start Screen
2 = Audi S4 Start Screen
3 = Audi RS4 Start Screen
4 = Audi TT Start Screen
5 = Audi R8 Start Screen
Thats for the main RNSE nag screen, not the DIS of course...
Gone but never forgotten:
- Surrey Sam
Re: Satnav
The logo only became available to select with later firmware - version 0650 I believe, so earlier firmware versions will not have it to select from.
I think the OP's problem is that the RNS-e has not been fully coded to the car, it may've had a symphony system originally and then had the RNS-e retrofitted.
- PetrolDave
Re: Satnav
The coding change you need is to the instruments at address 17, not to the RNS-E see http://wiki.ross-tech.com/wiki/index.ph ... 8ED/8HE%29JmRS4 wrote:Not 100% sure if it's been in from new. Satnav all works except the drivers info screen, it just made me think when my mate said about it.
You need to add 4 to the value in adaptation channel 62.
Re: Satnav
Thanks for your replies. I've tried turning the compass on and that does nothing. Ive also got Vagcom and change the settings on channel 62 from 17 to 4. That's if I'm in the right thing lol
Re: Satnav
Reread the instructions! 17 to 4 makes no sense, that's NOT adding!
Re: Satnav
Added 4 to the value that was in the box. Still no joy though.
Users browsing this forum: No registered users and 286 guests
