New Brake Pad Retaining Pins
- 2nd Gear
Change over the discs so I could give the ones that were one the car a skim. I work offshore and with the car lying for weeks at a time it does not help the discs any. It just give the corrosion more time to eat into the discs and when you get back in the car after 2 weeks away it sounds truly horrendous.
When I was in about the front discs I thought I would clean up the pads and the slider pins as I had an advisory from the last MOT that the front left was binding/sticking slightly.
The pad retaining pings were seized solid so had to drill these out.
First step was to cut the pins on the inside of each lug leaving the sections of the pins stuck in the holes. I drilled these but not all the way just enough so the parallel pin would not keep slipping off each time I hit it. I hammered the the out side ones out first. Then I used an extra long cobalt drill (4mm dia 126mm length drill bit) to reach through and drill the inner pin. May parallel pins were not long enough to reach through the 2 holes so I machined a grade 12.9 bolt down so the parallel pin would in one end and other small enough to fit into the partial hole I drilled then chapped it out. ( and yes may parallel pins are the long series ones)
I was not prepared to pay £40 for 4 new pins from Audi, So I turned 10mm stainless 316 bar down to 6mm leaving a 10mm head on one end and drilled the other for stainless split pin.
Hope this info mayt help some one in the future.
- 2nd Gear
Re: New Brake Pad Retaining Pins
Now that I think about it, I should have milled flats onto the 10mm heads so you could put a spanner or shifter on encase It needs a wiggle to remove them again.
- Surrey Sam
Don't think that will cure your binding issue. You can see that there is (galvanic?) corrosion bubbling up from under the pad retaining plates which then pinch the pad backing plate, this is starting to happen on your calliper as the backing plate is just starting to bend away from the pad.
The torx screws are a real PITA to remove and will likely shear or the heads round off. I decided to send my callipers off for refurbishment where they were stripped down, pistons polished, new seals, new plates/fixings and new paint. Cost was about £240 if I remember correctly.
- 2nd Gear
Hi Sam,
Yeah I had to remove the stainless plates and remove the white aluminum corrosion due to the road salt and other contaminants. I did round the heads of the small M5 screws but I hammered in a large torx bit and removed them and replaced all 12 screw with new stainless ones. I was thinking about stripping them down and getting them re powder coated.
What was the company you used for the caliper refurb?
- Surrey Sam
You have been busy thenandroidmarrs wrote:Hi Sam,
I had Godspeed Brakes do mine, have a look at their facebook page as they post up here and there a few re-furbs/stories. Will be sending another set off to them later this week.
- 2nd Gear
Thanks Sam will check them out!
Andy
Andy
Do you know what length these screws were androidmarrs? I'm looking at doing this myself. I intend to repainted underneath where these plates are.androidmarrs wrote:Hi Sam,
Shouldn't the pad retaining pins be inserted from the back of the calliper so if they do become corroded and difficult to remove you can use a punch and hammer to knock them out from the front of the calliper.
Audi RS6 c7 2014| Estoril Blue | Dynamic pack | Sports Exhaust.
Yip thats correct, the original pins have a barrell on the end which compresses in the lug to retain it , the ones he has are split pin type
1/4 mile 12.01 secs 123.5mph
Users browsing this forum: Bing [Bot], dan32v and 356 guests
