Swapped my RNS-E with a 2012 unit, thought it was just a plug and play install until I tried to insert the sat Nav CD, as soon as it partially in the motors come on and it is trying to pull the disc in, but it only gets as fas as the hole in the disc.
Has anybody had the lid off of one these before, I imagine something just got jiggled out of place while the unit was being posted
Insertion issue
- 2nd Gear
Insertion issue
Current - 07 Avus Silver B7 RS4 Avant : Ceramics, Non Valved Non Res Milltek, K&N filter, SS+, adaptive xenons, black optics, KW3, 034 rear ARB, rear drop links & front adjustable top arms.
Past - 00 Saxo VTS : 266mm Mi16 calipers, Quaife ATB, 20mm torsions bars, 24mm ARB, Vibratechnics mounts
87 Vauxhall Belmont: 1.6L, 15" rockford fosgate subwoofer in 3 cuft sealed box, 5ch Rockford fosate amp, JBL components
- RossDagley
- Top Gear
Re: Insertion issue
I came here looking for something much more interesting...
Sorry I can't help with your RNSE issue
Previously:
Previously:
Re: Insertion issue
Ditto.RossDagley wrote:I came here looking for something much more interesting...
You sure there is no disc in there already?
- PetrolDave
Re: Insertion issue
+1MikeFish wrote:You sure there is no disc in there already?
The top cover comes off fairly easily once you have the unit out and on a bench or table.
- 2nd Gear
Re: Insertion issue
OK cool, I'll have the lid off when I get the chance.
Re: Insertion issue
irn_bru_ce wrote: but it only gets as fas as the hole
your deffinatly trying the disk and not your penis right?
