Starting issue
Starting issue
Evening.. I've been getting the delayed start problem with the push button for a couple of weeks and yesterday morning the car refused to start at all.
I could hear the click behind the dash but no start. It eventually did start after 10 mins of swearing at it. Thought it might be clutch switch but it's been replaced in the last 2 months by the previous owner and I tried the hold button down test and still no start.
I read a thread saying it could be starter motor or the relays but I'll obviously try the relays first.
Thing is it's been fine today, no problems and I've had at least 5 starts throughout the day. If a starter was fect, would it not be permanently fect and not start at all?
On a positive note, I had a non res Miltek fitted yesterday, so every cloud..
Current - 07 Sprint Blue RS4 Avant Black optics / Buckets / FBSW / MRC Stage 2 / De flapped Manifold / CAF / BMC filter / Decat / Non Res Miltek / Bilstein B16's / Tarox discs, pads and lines / H&R ARBs / 19x9.5 Ispiri ISR1 wheels / MPSS tyres / DTM carbon splitter
Previous - 06 Sprint Blue B7 S4 Avant JHM 91 tune / 2.5" Custom Cat-less DP's / Miltek Non Res Cat back / BMC filter / H&R springs / 19" Fox MS007 wheels/Good Year F1's / EBC TG discs / Yellow stuff pads
- RossDagley
- Top Gear
Re: Starting issue
Mine was the same replaced starter and problem solved. Also was notable how quick the engine cranked / how fast the car started on a new starter. Really made a difference. Hadn't noticed until after replacement how tired it had become.
Previously:
Previously:
Re: Starting issue
I had a starter issue too, the connectors into the back of it had corroded. Took West London Audi 5 weeks of looking to find the problem because "the computer says there isn't a fault".
RS4 Cabriolet - Phantom Black with Exclusive interior
Re: Starting issue
Sh!t..Was hoping it was a relay.
I believe fitting the starter motor is a pita, subframe drop and 4 hours labour have been mentioned.
Thanks for info.
Thanks for info.
Re: Starting issue
Never thot should have had a quick look while we had it on the ramp doing the milltek. Might just be a lose wire.ASC wrote:Sh!t..Was hoping it was a relay.
Thanks for info.
RS4 B7 Saloon Milltek Cat back, CAF with piper cross panel, Wrapped optics black, Satin black wheels, TRUPS LED front DRL's & sides, goodridge braided hoses, H&R 10/15mm spares front/rear
Bilstien B16 coilovers with H&R anti roll bars
MRC stage 2 deflapped, precat gutted 439ps 481nm torque
1/4 mile time 12.884sec
My clutch replacement write up can be found here viewtopic.php?f=35&t=116929&start=15
Re: Starting issue
That would be a boost if it was a simple fix. It's going back into NEM next week anyway, still nae happy with coilies!
- RossDagley
- Top Gear
Re: Starting issue
Iirc I had my starter motor done at hitchin Audi for £380. As in bought and fitted for that.
Previously:
Previously:
Re: Starting issue
Cheap fix, you can get them under the Valeo part number (same as OEM) for much less and it's an easy replacement. IIRC I paid less than 100 quid for one.
981 Cayman GTS Gray/Orange.
My youtube
My youtube
Re: Starting issue
Stoke Audi previously quoted £315 for a new starter or £224 if you send your old one back.
Re: Starting issue
I can get a Lucas unit for £180 from Eurocarparts and a Valeo for £133 from West Lancs Auto. Is there much difference between the two, apart from £47?
- 2nd Gear
Re: Starting issue
You tried Taylors Auto electrical in Mastrick?
I've had a few Bosch starters from them in the past
Current - 07 Avus Silver B7 RS4 Avant : Ceramics, Non Valved Non Res Milltek, K&N filter, SS+, adaptive xenons, black optics, KW3, 034 rear ARB, rear drop links & front adjustable top arms.
Past - 00 Saxo VTS : 266mm Mi16 calipers, Quaife ATB, 20mm torsions bars, 24mm ARB, Vibratechnics mounts
87 Vauxhall Belmont: 1.6L, 15" rockford fosgate subwoofer in 3 cuft sealed box, 5ch Rockford fosate amp, JBL components
Re: Starting issue
Yeah tried them thanks mate but they couldn't find the part in their system. Then they asked if I wanted to book the car in to test the starter motor to see if that was the problem or not at £75 p/h + VAT.. lol
Anyone know what tests I could do to rule out relays and the push button before I buy the Valeo unit? Also where exactly is the starter?
Re: Starting issue
There is a thread from a while back. I think you can hear a click if the button and relay work. I'll see if I can dig it out.
Re: Starting issue
Take a look here:
viewtopic.php?f=35&t=109382
Re: Starting issue
Thanks for that Mike. Good reading and it really sounds like my starter is on its way out.
Users browsing this forum: Google Adsense [Bot] and 256 guests
