Exhaust flaps
Posted: Sat Jul 04, 2015 8:30 pm
by munsen99
One of my exhaust flaps has seized in the closed position and one in the open position. If I try and brute force the closed one, do i apply pressure to top or bottom half of the flap?
Re: Exhaust flaps
Posted: Sat Jul 04, 2015 8:47 pm
by docurley
soak it first with a penetrating solution before trying to free it up.
Re: Exhaust flaps
Posted: Sat Jul 04, 2015 11:02 pm
by MikeFish
Can't remember which way it goes, but if you shine a torch up the one that works and get someone to press the sport button a few times while ticking over you will see which way they turn.
Re: Exhaust flaps
Posted: Sun Jul 05, 2015 8:07 am
by munsen99
Thanks Mike. The other one had seized open, so difficult to tell which way it goes.
Re: Exhaust flaps
Posted: Sun Jul 05, 2015 9:11 am
by MikeFish
As yes, sorry I misread that. Mine are disconnected and probably seized now so can't really help I'm afraid.
Re: Exhaust flaps
Posted: Sun Jul 05, 2015 2:12 pm
by orangepeel
Top pushes back if that helps
Re: Exhaust flaps
Posted: Sun Jul 05, 2015 2:13 pm
by Grandadg90
The flaps open sideways i think. I would disconnect the vacuum line, apply wd40. Give it 5 minutes and then apply some force.
Re: Exhaust flaps
Posted: Sun Jul 05, 2015 6:10 pm
by coldo
Soak it in some WD40, get a broom handle that covers half of the flap, then chap on the end of it gently with a hammer until you start to get some movement.
Re: Exhaust flaps
Posted: Tue Jul 07, 2015 8:32 am
by munsen99
Top tips. I will give it a try this weekend.
Re: Exhaust flaps
Posted: Tue Aug 25, 2015 6:06 pm
by RSCosworth
Just followed this procedure on mine as the flaps were seized shut & it's worked a treat! I want to keep the flaps open now so in order to do that do I just disconnect the rubber vacuum pipes at the side of the exhaust & if so, do I need to put anything over the ends of the pipes/actuators once disconnected or just leave them hanging in mid air etc??
Re: Exhaust flaps
Posted: Tue Aug 25, 2015 6:34 pm
by PetrolDave
RSCosworth wrote:do I need to put anything over the ends of the pipes/actuators once disconnected or just leave them hanging in mid air etc??
You must seal the vacuum pipes - otherwise none of the vacuum operated flaps on the engine will work properly and you'll probably lose about 60bhp (estimate from Doug at MRC).
Just find a correct sized bolt, and screw that into the end of the pipe.
Re: Exhaust flaps
Posted: Tue Aug 25, 2015 7:56 pm
by alefustec
Golf tees are best, just push them in there hide pipes in rear diffuser and job done. Most satisfying 10 mins I have spent in a while
Re: Exhaust flaps
Posted: Tue Aug 25, 2015 8:15 pm
by RSCosworth
PetrolDave wrote:RSCosworth wrote:do I need to put anything over the ends of the pipes/actuators once disconnected or just leave them hanging in mid air etc??
Done! Cheers matey
Re: Exhaust flaps
Posted: Mon Nov 02, 2015 9:14 pm
by Fatneck73
Evening all
I have just viewed a car whose flaps didn't open - neither of them. The bolster worked perfectly and everything else about the car was great... And so my question: if I try the lube and yet can't get theses to manually free up and start working fine, what else could it be?
Cheers,
