Misfire under full throttle
Posted: Sat Jun 20, 2015 2:58 pm
by Rs-mad-burfy
Hello,
I'm getting a misfire, noticeably in 6th gear when the revs get to around 3500 when peddle is right down! It's not a constant, there's no rethumn to it.
Any ideas? No warning lights on.
Andy
Re: Misfire under full throttle
Posted: Sat Jun 20, 2015 6:06 pm
by NJMAudiRS4
Could be a number of issues but your usuall suspects are, Coil pack starting to loose the will to live, possible spark plug starting to fail, MAF sensor dirty or breaking down.
Is your car standard ? Have you had a remap ? What fuel are you using ?
Another possibility could be a vac leak
These are all things you can check by yourself with the minimum of mechanical nounce. Use the search function button and it can help you find all the info needed
I hope you get it sorted
Posted: Sat Jun 20, 2015 6:07 pm
by GlenRS
Some sort of ignition break down under compression. Check your spark plugs and then coil packs.
VCDS should tell you which cylinder to check first.
Posted: Sat Jun 20, 2015 8:27 pm
by Rs-mad-burfy
Thanks guys I'll check it out and let you know!
Thanks again
Andy
Posted: Sat Jun 20, 2015 9:21 pm
by R1RS4
Do you have vcd's?
First check if any faults show or they do not clear down
If they do clear down ie not showing any faults
Do a search on engine misfire/misfiring
I had the same thing and it took many hours to resolve
Any other things not quite right with the way in which it runs?
Good luck
Posted: Sun Jun 21, 2015 12:00 pm
by audi_do_dat_den
Id start with a VCDS scan, then a call to Audi to see if you missed the coilpack re-call campaign (you may well get a new set of coil packs for free)
It would be worth changing plugs also if theyve been in a while.
Posted: Sun Jun 21, 2015 8:33 pm
by E14STO
I've had this twice in last 3 months, most recently this week.
Lambda sensor first time, new maf friday.
Posted: Mon Jun 22, 2015 9:31 pm
by S4Player
E14STO wrote:I've had this twice in last 3 months, most recently this week.
Surely not still chewing maf's?
Posted: Tue Jun 23, 2015 9:01 am
by E14STO
First one I've had since owning, 10k miles in...
I can cope with that tbh.. :-)
Posted: Tue Jun 23, 2015 9:10 am
by S4Player
I was one every bloody month then it settled
Posted: Tue Jun 23, 2015 9:25 am
by E14STO
It's had coil packs, lambdas, maf - so hopefully it's gonna run sweet for another 10k minimum!
Was gonna sell it this summer but a couple TTs cars up for sale so not ideal.
Sorry OP - not meant to hijack
Hope it's an easy fix as above!
