Page 1 of 3
20" Wheels but keeping with Original Style
Posted: Wed Jun 17, 2015 8:23 am
by anawaz
I note there are 20" wheels on eBay that are same style as the original B7 alloys ...
Some are from Q5 and there's a set of ex TT rims.
Just want to confirm these are good to go with right?
i.e. 9 x 20 et25
Here are a set of et29, but to be honest I don't know if they're too big or not.
http://www.ebay.co.uk/itm/20-GENUINE-AU ... 3cfb18ea97
Re: 20" Wheels but keeping with Original Style
Posted: Wed Jun 17, 2015 9:51 am
by davers6
That'll be 1 wheel
Posted: Wed Jun 17, 2015 10:02 am
by bam_bam
THIS.
davers6 wrote:That'll be 1 wheel
Posted: Wed Jun 17, 2015 11:14 am
by DaytonaRs4
I'm also looking at various options for wheels at the moment...
yeah the ad is only for one wheel, but i believe that is the correct size / offset of OEM 20" wheel for B7 RS4 (Audi S5 20x9 et29 wheel),
Be careful though as some other Audi's have that same wheel in different offsets and you will have to run spacers, also if your car is lowered you might have to go down to 255 or 245 width on the tyres.
Spigot adapters will be needed also to step down from 66 to 57 center bore..
theres a few sets on ebay with suitable offset..
http://www.ebay.co.uk/itm/Genuine-VAG-A ... 1a01231410
Posted: Wed Jun 17, 2015 11:58 am
by boombastik
I have a genuine set of 20" speedline Lemans style alloys (same as B7 RS) with 9 x 20 et29 but the centre bore is 66.6 so they came off of a S5
you can buy adaptor rings to reduce the centre bore to 57.1mm so they fit perfectly on the RS4 with same offset & width
I haven't fitted them to my RS4 yet as I had them on my S5 but took them off before trading it in.... but plan to put them on when I get my 19's refurbished
Posted: Wed Jun 17, 2015 8:34 pm
by TAB1S
boombastik wrote:I have a genuine set of 20" speedline Lemans style alloys (same as B7 RS) with 9 x 20 et29 but the centre bore is 66.6 so they came off of a S5
I have this set up also & imo its the best! also lowered on kw v3's with 265/35's, 10mm rear & 8mm front spacers with no rubbing.
Posted: Wed Jun 17, 2015 9:43 pm
by MikeFish
I agree that the 20x9 ET29 size offset with 255/30/20 tyres will work in the same way as the OEM wheel as it is a direct size comparison therefore it will rub as much or as little as your standard set up.
However, most people with OEM wheels like to add spacers to bring the wheels out slightly. So if you buy wheels with a lower offset they could make the need for spacers redunant. For example the ET25 wheels you mentioned will instantly give you the same effect as a 4mm spacer.
If you go for larger tyres then you *may* have rubbing issues (I assume TAB1S means 265/30 tyres and not 265/35) as a 265/30/20 will be higher and wider than a 255/30/20 tyre.
Posted: Thu Jun 18, 2015 8:21 am
by RS04YOB
Not the greatest of pics this is mine with 20s lowered on Bilstiens
Posted: Thu Jun 18, 2015 2:10 pm
by anawaz
Hi RS04YOB
Agree about the pic
can i ask, did you have to do anything in terms of spacers/bore hole size?
cheers
Posted: Thu Jun 18, 2015 7:19 pm
by TAB1S
MikeFish wrote:I agree that the 20x9 ET29 size offset with 255/30/20 tyres will work in the same way as the OEM wheel as it is a direct size comparison therefore it will rub as much or as little as your standard set up.
Yes sorry 265/30/20
Posted: Fri Jun 19, 2015 9:38 am
by RS04YOB
anawaz wrote:Hi RS04YOB
Agree about the pic
cheers
Think there are 10mm spacer they are 10J wheels also
Posted: Fri Jun 19, 2015 7:29 pm
by MartayMcFly
That's my last one with 20x9 ET25 and 255/30R20 GYEagleF1s, lowered on KW coil springs.
Posted: Fri Jun 19, 2015 8:08 pm
by ChrisW
20" Speedlines from a Q7
Posted: Fri Jun 19, 2015 8:46 pm
by Covkiller
Posted: Fri Jun 19, 2015 9:12 pm
by ChrisW
I need lows like that ^
