Inlet Spacers Group Buy
Posted: Fri Jun 12, 2015 6:54 pm
ive taken some inlet sppacers to my locaal machining Shop to get some spacers made or the inlet manifold, im also having some inlet to throttlebody spacer made also to help dissapate heat and to stop heat transfer.
im having them made from 8mm tufnol which will be then best material to keep the cost down.
i have no pics as yet but be with me within 10 days
What do they do?
They help bring your intake temps down by insulating the intake manifold from the heat coming from the cylinder heads due to combustion and lengthen your intake runners which in turn creates more torque. With a cooler intake manifold you create a cooler and denser intake charge which helps add more tq and hp, gear after gear! All in all a great mod for the money especially on the RS4 that is lacking in the torque department. With our in house testing we found a gain everywhere in the rev range from 2500 rpm to 8000 rpm. The biggest gains were from 4000 to 6000 rpm, with the 2nd best area of gains from 5000 to 7000 rpm. This was done with acceleration rate calculations in 3rd gear from logs. The BEST part is that we saw that the car didn't slow down after repeated pulls due to an extremely heat soaked intake manifold bringing the intake temps up. Bottom line, the longer we beat on it the better it performed vs. the tests without the spacers.
i think the cost of the full kit will be about £100, just for reference JHM do the inlet only kit for 185 plus shipping and tax
this will include
2 x 8mm inlet spacers
2 x oem gaskets
8 x longer bolts
8 x washers
1 x 8mm throttle body spacer
1 x oem throttle body gasket
it will be limited to 10 first then will see if the demand is there ill get more
What do they do?
this will include
2 x oem gaskets
8 x longer bolts
8 x washers
