Headlight love (upgrade)
Well Trup came round on Saturday to apply his latest RS4 upgrade to the projectors. The lenses come in plain and etched and the etching does not effect the output.
I measured the light output using a android app on my Samsung which was not calibrated in anyway so the readings as in figures should be ignored but the varrient is what we are looking at.
Stock showed 1990 lumens and Trup's showed 2300 lumens.
What was found is that I had two different bulbs in the car and the colour difference is now quite apparent with the new lenses.
Re: Headlight love (upgrade)
these look awesome,
unfortunatly ive already swapped my lense tor the STI ones they are loads clearer,
i love the RS logo in then thats really trick.
how do i order some sidelight resistors please?
- 2nd Gear
Nice.. :rocker
How much trimming to the frame or lens did you have to do the get the sti r ones on? I had a read that it's a lot more involved doing them.Rick_RS4 wrote:these look awesome,
You got a picture of your output?
Send me a pm for the sidelights and I can go through the order.
Trups
Looks good.
Trups
How much are you looking at for this set up? An what is includded or needed to get most out of it whilst doing the job.
Trups
Lukes3 wrote:Looks good.
Trups
And how long does it take? And can you tint the insides while you have the headlights open?
So new bulbs and the lens, lens can be plain clear or etched, both give same 30% upwards of extra light, when working on them if you wanted to change the reflector bowls I also have brand new ones in stock, I would only supply this if your are burnt out via usage or if you have had any water damage as they are expensive for two small pieces of chrome.Lukes3 wrote:Looks good.
Trups
Clear lens are £40
Clear etched are £75
New bulbs start from £50 upto £130 going for a more branded name upgrade such as the osram CBi and the Philips ultinon but all down to what colour you want it and personal preferences
Trups
if you wanted painting done depending on what it is, if its that trim at the front then I can pre paint a set as I have a few laying around, then if you wanted me to come fit it it would take a couple of hours, painting in advance will save a lot of time but I was only with doc for a couple of hours, no painting, just the lens swap and then had to find somewhere to align. as I have a separate D1s ballast i can power with a jump pack i managed to tune the sharpness and colourfull cutoff in his living room, if you can then its on the car in the evening before putting it back together.MikeFish wrote:Lukes3 wrote:Looks good.
Trups
Tuning is easy, there is a little screw on the projector, you turn it and see the difference and the sharpness will change.
Trups
I just had Trups work on my lights a few days ago (see my thread for more info). He asked I post this pic here of the light output after the clear lens mod and 6000K morimoto bulbs. Took this on my way home on a pitch black country road.
I haven't doctored the image at all, it really is that bright! If anything the pic doesn't do the brightness justice. Even the Mrs noticed the lights were a lot brighter (that's saying something).
Well worth doing if you have your headlights open for painting etc.
2007 RS4 B7 Avant
And I I've just ordered a set of bulbs and that evil eye kit you got.
- PetrolDave
That's like the headlights on the first B6 S4 I owned back in 2003, definitely a great improvement over the B7 headlights.FaisalJ wrote:I just had Trups work on my lights a few days ago (see my thread for more info). He asked I post this pic here of the light output after the clear lens mod and 6000K morimoto bulbs. Took this on my way home on a pitch black country road.
Haha!docurley wrote:And I I've just ordered a set of bulbs and that evil eye kit you got.
I should be on commission.
Just be warned that the demon eyes aren't particularly bright. Still worth it as a bit of fun I reckon, and can be left turned off when you don't want to be all "look at me"!
Regarding the B6 S4, I had one of those too and I don't remember the headlights being as bright as mine are now. The B6 S4 xenons were similar to the B8 A4 I had, which were both better than the standard B7 RS4 lights...weird.
2007 RS4 B7 Avant
- PetrolDave
I had two B6 S4s - an early 2003 one which had fantastic lights (that's the one I compared against) and a 2005 one which had lights that were not as good but still better than any B7.FaisalJ wrote:Regarding the B6 S4, I had one of those too and I don't remember the headlights being as bright as mine are now. The B6 S4 xenons were similar to the B8 A4 I had, which were both better than the standard B7 RS4 lights...weird.
Trups applied his knowledge to my headlights a while back, some painting, lens swap, and replacement. very pleased
Whats the cost of the "demon eye" kit Trups?
Is it a DIY job to fit?
Users browsing this forum: Majestic-12 [Bot] and 155 guests
