Idle seems off
Idle seems off
My RS4 seems a bit rough lately when idling, can slightly hear it in the cabin when stopped at lights.
Quick vid below, is this normal?
https://youtu.be/5BUZNW0igmM
- NJMAudiRS4
Re: Idle seems off
Can't really tell much from the vid, there's is a slight change in pitch, I don't think it is anything to be concerned about, have you checked the oil lately ? was the engine cold and just started, was it already warm ? Has it had a service recently or does it need one. Possible coil pack starting to degrade or possibly spark plug. Do you have any error codes. These would be things I would be looking at just to reassure myself
Audi RS4 Avant. MRC Stage 2 Manifold, caf, Map, JCWF Manifold back Exhaust with Sports Cats, H&R spacers, 449ps & 483nm
Re: Idle seems off
Sounds tappy . Id be changing the oil .
Re: Idle seems off
Was serviced 6 months ago, engine was warm. did about 5k miles since last service. Checked and she was low on oil all right, put in 1.5l and will keep an eye on it. Would it need a full oil change?
Will look on VCDS for some codes tomorrow
Re: Idle seems off
Im fairly new to these cars but that sounds very tappy compared to mine . A thing I used to do with my cosworth is stick a really cheap oil in for 50 miles off boost , then dump it out and stick good stuff in. the difference was unreal
Find out what grade oil they put in it and get it changed ASAP inc filter etc . The oil sounds to thin .
Re: Idle seems off
Will do. It was serviced in the Audi main dealer so I assume proper spec castrol was used..
Although saying that I went in for some top up oil and they gave me Quantum, the service guy said that's the oil they use when servicing...
Re: Idle seems off
What grade ? I also have a Mercedes vito and I used cheap Halfords oil in that once and it hunted and idled all over the place . I put the good stuff in and it went back to normal .
Re: Idle seems off
5w30 VW/Audi Spec
From what i've read its a decent oil
Re: Idle seems off
Most of the tapping noise seems to be coming from the fuel injector pumps either side of the rocker covers. Isn't that normal?
Daytona RS4 Avant - black optics/decat downpipes/H-pipe/KW springs - featured on the 2012 Audi stand at the Goodwood FoS
Re: Idle seems off
It definitely is a bit more tappy than it used to be and it is slightly rougher ticking over, now it's not a massive change, but it was always really smooth, now I can hear it wandering a small bit.
Must hook up VCDS tomorrow and give it a scan, it's due new brakes soon so may get them to give it an early service too while I;m at it.
Users browsing this forum: No registered users and 147 guests
