RS4 B7 - MRC Installs TTS supercharger
Posted: Tue Apr 14, 2015 9:15 pm
Hi all,
Thought I would just give an update on my latest change to my car
Following the Surrey Rolling road day back in December, I had joked about saying if my car did not make 400+ then I would have to seriously think about changing things like maybe a charger
So I spent about 3 months investigating/considering different options, APR, Whipple, TTS, JHM ?
I contacted various members, companies, manufactures, considered installing myself, timings, reliability, output and mainly cost to arrive at a MRC installed TTS
I was hoping to have it ready for the recent run what you brung day at Santa pod, but it wasn't to be, to get the kit installed and running right is never plain sailing as many will know,
On the way to MRC for the first time in 18 months the car suffered a hesitant power loss, as luck would have it (intermittent)
Starter motor failed whilst there, covered under warranty (lucky)
Asked MRC to fit my new JHM oil cooler pipes, pissed out from the adaptors supplied with the kit, removed from car inspected refitted pissed out again - changed for OEM
Kit comes with upgraded fuel pump kit, removal of old intake manifold (hooray) no more flaps
The car drives as per normal up to about 3500 rpm then off she goes (flies)
The engine oil temperature I have noticed already runs a lot cooler, before at about 20 deg ambient the car would run 104 to 108 depending on driving now 99 to 102
Early days; on the beans about 12 mpg, a run on Sunday I did a 35 mile trip with a couple of bursts and cruised at 70 - 80mph, got out the car and it was showing 22.5 ? What I have noticed is with the extra power when your doing 70 to 80 the revs are a lot lower and less effort ?
I was worried about the standard brake set up, but as I have not changed my driving style just because of the SC, and still use engine braking where possible alls well for now
The down side I have since found out, that having my revolution intake air system removed (gone back to OEM with performance filter) I do miss that roar, but the off set is cooler air through the engine, and the roars back when the SC's full on
I have had only two goes at the 3k - 8k test
1st run; 6.3 sec
2nd run; 5.6 sec
Both with sport button off
1/2 tank Momentum 99 RON
130 Mtrs ASL
Ambient. 16.5 deg C
1st run; 6.3 sec
2nd run; 5.6 sec
130 Mtrs ASL
Ambient. 16.5 deg C
