VCDS error help needed after installing RNS-E MK2
- CaptainLeadFoot
- 2nd Gear
Hi,
Also ordered the glossy RNS-E from fleabay, except the re-wiring took a bit of time (the connectors are a bit jammed after pushing them out from the socket...), the installation was a bliss and simple.
I have re-coded from Symphony II+ so the previous code was 0030101, the unit came pre-coded with 0309758.
But since I have no additional accessories fitted other than the 6 stack CD in the glove box, I have modified it to 0339153.
I have noticed the park asisst is actually set to 0000114, should it be changed to 0000414 for the Euro RS model ??
After scanning from VCDS and clearing some code, these still remain. I haven't installed the GPS antenna yet so the first fault is known. Could someone assist with the other 2 faults ?
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8P0 035 193 B HW: 8P0 035 193 B
Component: RNS-E PU EU H06 0220
Revision: 0000012S Serial number: AUZBZ7L6100457
Coding: 0339153
Shop #: WSC 00030 211 18254
VCID: 2F6D0B0BBD8A5759C75-5106
3 Faults Found:
00862 - Antenna for GPS Navigation (R50/R52)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 87
Time Indication: 0
Date: 2015.04.12
Time: 17:16:17
Freeze Frame:
Mileage: 655350 km
Count: 1204
Clock: 18:59
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 5
Fault Frequency: 1
Reset counter: 87
Time Indication: 0
Date: 2015.04.12
Time: 17:16:28
Freeze Frame:
Mileage: 655350 km
Count: 1204
Clock: 17:16
03157 - Functionality limited due to Communications Disruption
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 87
Time Indication: 0
Date: 2015.04.12
Time: 17:19:26
Freeze Frame:
Bin. Bits: 00000100 00000000
Bin. Bits: 00000000 00000000
Thanks for your help in advance !
Coding: 0339153
3 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 87
Time Indication: 0
Date: 2015.04.12
Time: 17:16:17
Freeze Frame:
Mileage: 655350 km
Count: 1204
Clock: 18:59
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 87
Time Indication: 0
Date: 2015.04.12
Time: 17:16:28
Freeze Frame:
Mileage: 655350 km
Count: 1204
Clock: 17:16
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 87
Time Indication: 0
Date: 2015.04.12
Time: 17:19:26
Freeze Frame:
- PetrolDave
Re: VCDS error help needed after installing RNS-E MK2
They're all "Fault Frequency :1" so clear them and see if they come back as they might have been set during the install.
- CaptainLeadFoot
- 2nd Gear
Thanks for the tips PetrolDave. I think I might need to change the code to 0309153.
Below is the first set of errors that I have after install when the unit was first in. I have cleared them and put in 0339153.
So the final one "03157 - Functionality limited due to Communications Disruption" hopefully should disappear.
The error "00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier, 007 - Short to Ground", will this be linked the the GPS antenna ??
10 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 81
Time Indication: 15
Freeze Frame:
Mileage: 655350 km
Count: 1104
Clock: 22:11
01305 - Databus for Infotainment
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 12
Reset counter: 83
Time Indication: 15
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 85
Time Indication: 0
Date: 2015.04.11
Time: 22:11:53
Freeze Frame:
Mileage: 655350 km
Count: 1104
Clock: 22:11
02005 - Coding Pin
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 125
Time Indication: 15
00878 - Connection to Speaker Front Left
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00111011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 123
Time Indication: 15
00879 - Connection to Speaker Front Right
011 - Open Circuit
Freeze Frame:
Fault Status: 01111011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 81
Time Indication: 15
00857 - CD Changer Unit (R41)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 125
Time Indication: 15
00466 - Control Module for Steering Column Electronics (J527)
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 85
Time Indication: 0
Date: 2015.04.11
Time: 22:12:40
01303 - Telephone Transceiver (R36)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 85
Time Indication: 0
Date: 2015.04.11
Time: 22:12:46
00467 - TV Tuner (R78)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 85
Time Indication: 0
Date: 2015.04.11
Time: 22:12:58
10 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 81
Time Indication: 15
Freeze Frame:
Mileage: 655350 km
Count: 1104
Clock: 22:11
Freeze Frame:
Fault Priority: 5
Fault Frequency: 12
Reset counter: 83
Time Indication: 15
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 85
Time Indication: 0
Date: 2015.04.11
Time: 22:11:53
Freeze Frame:
Mileage: 655350 km
Count: 1104
Clock: 22:11
02005 - Coding Pin
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 125
Time Indication: 15
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 123
Time Indication: 15
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 81
Time Indication: 15
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 125
Time Indication: 15
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 85
Time Indication: 0
Date: 2015.04.11
Time: 22:12:40
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 85
Time Indication: 0
Date: 2015.04.11
Time: 22:12:46
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 85
Time Indication: 0
Date: 2015.04.11
Time: 22:12:58
Has your car done over 400k miles?
- CaptainLeadFoot
- 2nd Gear
ohh...!! interesting...VCDS reported mileage: 57320km-35616miles.
is therer something i need to check for this ??
655350km in the last post.
No idea why that would be different from dash mileage though.
- CaptainLeadFoot
- 2nd Gear
Yeah I noticed that too but have no idea on that also...VCDS bug ?
If you don't get any answer in this thread maybe start a new one for the mileage issue.
- PetrolDave
No it's not related to the GPS antenna at all.CaptainLeadFoot wrote:The error "00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier, 007 - Short to Ground", will this be linked the the GPS antenna ??
That's normally caused by either a bad connection to one of the diversity antenna inputs at the rear of the RNS-E or by upgrading from a Symphony II+ to an RNS-E (the Symphony II+ uses a different diversity system to the Symphony II and RNS-E)..
- CaptainLeadFoot
- 2nd Gear
Oh...does that mean I need another antenna ? the connector is the same as the RNS-E though...I'm upgrading from Symphony II+, is it safe to ignore ? Will there be any damage to the RNS-E in the long run ??PetrolDave wrote:No it's not related to the GPS antenna at all.CaptainLeadFoot wrote:The error "00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier, 007 - Short to Ground", will this be linked the the GPS antenna ??
- CaptainLeadFoot
- 2nd Gear
I've tried the re-coding, then reset the RNS-E, I noticed they all come out only after the reset and subsequent start/stop engine won't trigger the fault code.PetrolDave wrote:They're all "Fault Frequency :1" so clear them and see if they come back as they might have been set during the install.
So I guess it's ok for now, but will the battery be drained or leak out to the chasis with the Antenna throwing a short to ground code ?
- PetrolDave
You have two choices:CaptainLeadFoot wrote:Oh...does that mean I need another antenna ? the connector is the same as the RNS-E though...I'm upgrading from Symphony II+, is it safe to ignore ? Will there be any damage to the RNS-E in the long run ??
- live with it, which is what the vast majority of people who do the II+ to RNS-E upgrade do;
- completely refit the antenna diversity system, which is a real PITA.
It's only a problem if you live in an area with really poor FM reception as you won't have an antenna diversity system any more - but most cars don't have one anyway!
It won't cause any problems with extra power drain or the RNS-E staying on.
- CaptainLeadFoot
- 2nd Gear
Yeah totoally agree with you PetrolDave, as long as there's no safety or equipment concerns I'll leave it. The radio frequencies in Hong Kong here are pretty strong so it's not going to be too painful for me.
I read the posts on other forums, does it really need to change the glass on the rear hatch to have the correct antenna fitted ?
- PetrolDave
No, one guy (a few years ago) did it just by changing the two antenna amplifiers to convert them back to the old diversity system.CaptainLeadFoot wrote:I read the posts on other forums, does it really need to change the glass on the rear hatch to have the correct antenna fitted ?
Users browsing this forum: No registered users and 519 guests
