My n/s/r door wont open
Posted: Sun Feb 22, 2015 8:07 pm
by denboy1
Happened this weekend, will not unlock by key fob OR from handle inside. Can't work it out. :?
Re: My n/s/r door wont open
Posted: Mon Feb 23, 2015 10:39 am
by Harris.
My old A4 did this , so I took it to Audi and the guy in the service yard thumped the door next to the handle and it stated working !!!! Weird I know
Posted: Mon Feb 23, 2015 11:16 am
by denboy1
Harris. wrote:My old A4 did this , so I took it to Audi and the guy in the service yard thumped the door next to the handle and it stated working !!!! Weird I know
Lol, i'll give it a go, not very hopeful though.
Posted: Mon Feb 23, 2015 1:42 pm
by docurley
It could be one of two things and one being the rod that pulls the door handle which can become unlatched if it's been off before and not fitted correctly the other is the solenoid if that's what they call it on our cars; either way to get to it all till mean trashing the door card to get to it.
Posted: Mon Feb 23, 2015 2:06 pm
by neilparf
It could be the lock microswitch that has jammed/gone. New lock which is an expensive pain or this: http://www.vwaudiforum.co.uk/forum/show ... G-vehicles
Godo luck!
Posted: Mon Feb 23, 2015 3:32 pm
by docurley
I have a couple of rear doors and parts hanging around so if you need something I'm sure I will have it but no door cards I'm afraid, need a drivers door card myself.
Posted: Mon Feb 23, 2015 4:44 pm
by denboy1
If I lower n/s/r window, is there any way I could stick something like a coat hanger etc in the gap and pull the rod to get it open?
Posted: Mon Feb 23, 2015 7:02 pm
by docurley
denboy1 wrote:If I lower n/s/r window, is there any way I could stick something like a coat hanger etc in the gap and pull the rod to get it open?
possible...... yes maybe, I would popthe other door card off to see if there is a way.
Posted: Mon Feb 23, 2015 9:16 pm
by denboy1
possible...... yes maybe, I would pop the other door card off to see if there is a way.
Good idea. :wink:
Posted: Mon Feb 23, 2015 11:17 pm
by Cabar Feidh
I had the same problem with my drivers door. Put it into Aberdeen Audi and they had it for 2 1/2 days until I got it back with a bill for £750! It was the deadlock motor that had failed and they had to wreck the door card to get it open before the could fix it. Would have been another £300 if I'd let them replace the carbon fibre trim which they slightly marked as well. Can't really see it unless you know where it is so didn't get it done. Probably be slightly less for a rear card but getting a 2nd hand one in advance would be beneficial. I did manage to get a free service after I KUF with Customer Services and wrote to the MD. There's some more detailed posts if you search for them.
Mike
Posted: Mon Feb 23, 2015 11:34 pm
by denboy1
Cabar Feidh wrote:I had the same problem with my drivers door. Put it into Aberdeen Audi and they had it for 2 1/2 days until I got it back with a bill for £750! It was the deadlock motor that had failed and they had to wreck the door card to get it open before the could fix it. Would have been another £300 if I'd let them replace the carbon fibre trim which they slightly marked as well. Can't really see it unless you know where it is so didn't get it done. Probably be slightly less for a rear card but getting a 2nd hand one in advance would be beneficial. I did manage to get a free service after I KUF with Customer Services and wrote to the MD. There's some more detailed posts if you search for them.
Mike
Cheers Fella, £750 seems well steep, if it comes to it, i'll try the door card first, failing that , i'll just leave it for now...............................or sell it. :lol:
Posted: Tue Feb 24, 2015 4:24 pm
by Grandadg90
The locking of the door and the electric window is controlled by a control module located in the rear door. If the module fails, you cant open the rear door or lower the window.
Check with Audi for prices of the module.
Posted: Tue Feb 24, 2015 7:33 pm
by denboy1
Grandadg90 wrote:The locking of the door and the electric window is controlled by a control module located in the rear door. If the module fails, you cant open the rear door or lower the window.
Window goes up and down fine.
