Xenon out, dash fault and VCDS error code
Posted: Sun Feb 01, 2015 7:51 pm
SO today my drivers side xenon failed. I hot a dash warning about dipped beam, checked and the bulb was out.
I have the following two VCDS faults and assume this relates to the left fault (02233)but this would mean left is when looking at the car head on rather than from inside the car. The other side does not seem to have any bulbs out, etc so confused why I have a fault code on both sides.
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 L
Component: int. Lastmodul ECE 0704
Coding: 01021
Shop #: WSC 06335
VCID: 3B75D16729907BC6811-4A9C
1 Fault Found:
00979 - Lamp for Low Beam; Right (M31)
30-00 - Open or Short to Plus
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 E HW: 4F0 907 357 E
Component: AFS 1 H01 0010
Revision: 00000001 Serial number:
Coding: 0000019
Shop #: WSC 06335 000 00000
VCID: 285F1E2B9B06C05EFC3-807D
Subsystem 1 - Part No: 8E0 941 329
Component: AFS-Modul links H03 0020
Subsystem 2 - Part No: 8E0 941 329
Component: AFS-Modul rechtsH03 0020
1 Fault Found:
02233 - Left Headlight Power Output Stage (J667)
014 - Defective - MIL ON
Freeze Frame:
Fault Status: 11101110
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
The 02233 fault was present previously a few months ago after a service and both DRL's where not working. I took the car back and they resolved the issue, but I'm not sure of the cause. I assumed one of the plugs hadn't been connected properly or was knocked when the removed trim to do the spark plugs, etc but the xenon bulb was definitely not out.
Wondering what the more likely cause is. Bulb, ballast, wiring, other.
Has anyone changed the xenon bulbs and is it a bumper of job?
Ross Tech wiki suggests the following:
02233:
Possible Causes
Fuse(s) faulty
Wiring from/to Left Headlight Power Output Stage (J667) faulty
Left Headlight Power Output Stage (J667) faulty/incompatible
Possible Solutions
Check Fuse(s)
Check/Repair Wiring from/to Left Headlight Power Output Stage (J667)
Check/Replace Left Headlight Power Output Stage (J667)
Check Left Headlight Power Output Stage (J667) Part Number/Compatibility
and
00997:
Possible Symptoms
Malfunction Indicator Lamp (MIL) active
Possible Causes
Lamp for Low Beam; Right (M31) faulty
Wiring/Connector(s) from/to Lamp for Low Beam; Right (M31) faulty
Control Module incorrectly coded
Possible Solutions
Check Lamp for Low Beam; Right (M31)
Check Wiring/Connector(s) from/to Lamp for Low Beam; Right (M31)
Check Control Module Coding
So could basically be anything. Is there a suitable way of checking and eliminating each potential cause?
Coding: 01021
Shop #: WSC 06335
1 Fault Found:
Coding: 0000019
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
02233:
Possible Causes
Fuse(s) faulty
Possible Solutions
Check Fuse(s)
and
00997:
Possible Symptoms
Possible Causes
Possible Solutions
