Gy eagle f1,s tyre pressures
Hi all, anyone running Goodyear eagle f1,s on there b7?? What pressures you running them at??.
Thanks!
Thanks!
rs4 b7 daytona avant. Miltek resonated valved, Mrc stage 2
vw touran 2.0tdi, blue /black leather. family wagon!!.
repsol honda fireblade.
Zx12r b1 in black and gold. The colour to have!!
Re: Gy eagle f1,s tyre pressures
Got them on mine, run them at 39 psi i think off the top of my head, never had an issue!
If they are standard size you should run them at the recommended pressures. I always did and had no problems.
If they are bigger wheels/lower profile should they differ?MikeFish wrote:If they are standard size you should run them at the recommended pressures. I always did and had no problems.
I always thought so but have never got a definitive answer from the Internet. Some say you should use the same pressure but my mind is telling me a lower profile tyre should be running a higher pressure but I might be wildly misguided.
I think this theory comes from the fact that the manufacturer of most cars gives a couple of options for wheel & tyre sizes in the manual or on the door shut. And ever time I've ever looked the bigger wheel / lower profile combo has had a different tyre pressure from the smaller wheel / bigger profile combo and pretty sure the bigger wheel has had the higher pressure.MikeFish wrote:I always thought so but have never got a definitive answer from the Internet. Some say you should use the same pressure but my mind is telling me a lower profile tyre should be running a higher pressure but I might be wildly misguided.
If by going up a wheel size you should keep the same pressure then why do the manufacturers say otherwise?
thanks lads. just curious as it feels very firm over poor surfaces. i think i,m running mine about 42 all round so might drop 3-4 psi out and see how it differs.
What does the book say? I can't remember off the top of my head but that sounds a little high to me.rocket1 wrote:thanks lads. just curious as it feels very firm over poor surfaces. i think i,m running mine about 42 all round so might drop 3-4 psi out and see how it differs.
Just checked the book and it says refer to the door pillar... D'oh!
Like i said 39 PSI
38 front, 35 rear from memory with three people in the car. Five people and it goes up to about 41.
thanks guys
