Need a spare key for the rs4
- RossDagley
- Top Gear
Re: Need a spare key for the rs4
Just been through this. Audi only im afraid.
Hope you're sitting down...
£150 for the key (pre-order from Germany), £55 to code it to your car. Hitchin cocked up something else so I managed to get it coded for free so it's obviously negotiable - but the key is damn expensive.
Previously:
Previously:
RossDagley wrote:Just been through this. Audi only im afraid.
MRC STAGE 2 RE-MAP
I thought there was a much cheaper way but I could be wrong. Still, it's better than the £250 Alfa charged me. I bought 2 for £500!!! Bargain!
Fail to see how that cost can be justified, ludicrous really.
MRC STAGE 2 RE-MAP
MikeFish wrote:I thought there was a much cheaper way but I could be wrong. Still, it's better than the £250 Alfa charged me. I bought 2 for £500!!! Bargain!
That's your own fault for buying an Alfa
Yeah I won't make that mistake again.davers6 wrote:MikeFish wrote:I thought there was a much cheaper way but I could be wrong. Still, it's better than the £250 Alfa charged me. I bought 2 for £500!!! Bargain!
- RossDagley
- Top Gear
Feel my pain.
Previously:
Previously:
If it is just for a spare you can also order a plastic key or a standard metal key which would reduce the cost.
Really need one with the transponder in. If i was to lose the original i wouldn't be able to start the car or turn the alarm off.MB2 wrote:If it is just for a spare you can also order a plastic key or a standard metal key which would reduce the cost.
MRC STAGE 2 RE-MAP
They know your car is performing healthy then - '450 PS' on the invoice!RossDagley wrote:
The plastic key has a transponder in and starts the car & they should be able to find you a non-remote metal key with a transponder in it.denboy1 wrote:Really need one with the transponder in. If i was to lose the original i wouldn't be able to start the car or turn the alarm off.MB2 wrote:If it is just for a spare you can also order a plastic key or a standard metal key which would reduce the cost.
With both of these I think you have 30 seconds or something to turn the key in the ignition before the alarm goes off but not entirely certain.
Users browsing this forum: No registered users and 161 guests
