Page 1 of 2
Another exhaust question
Posted: Mon Oct 20, 2014 6:41 pm
by Deano_123
I have non resonated centre pipes and Tubi Rumore backboxes, I'd only driven the car once since fitting this all a couple months ago. Got home yesterday and took the car for a drive today, brilliant noise but just far to loud. If I drive this home after 7pm it'll wake up the kid and the wife will kill me
So, anyway, options I have, resonated centre pipes with the Tubi backboxes or non resonated pipes with standard backbox
Thoughts on either of the above options?
Re: Another exhaust question
Posted: Mon Oct 20, 2014 7:15 pm
by RossDagley
Non res with standard boxes will give you the drone and little of the nice bits of the sound IMO. Res with tubi boxes might be better.
But in still keen to meet and hear yours - if you like mine and I like yours... Etc.
Posted: Mon Oct 20, 2014 8:12 pm
by MikeFish
The non-res makes it much more liveable. My wife moaned when I used to start the car in the morning, the non-res used to not only wake her up but actually make her jump. No problems when I swapped to the res. Still loud but much less enjoyable to drive. But you don't need to shout in car anymore either.
Posted: Mon Oct 20, 2014 8:22 pm
by harding
https://www.youtube.com/watch?v=6zI_9y9hH_o
So this one, what is actually "downpipes"?
I was about getting tubi, but since you Mike told me i was going to wake up the neighborhood i kinda try to get something else that sounds loud when revved but not that loud on idle? (my car is parked 10 meters from peoples bedrooms for 5 floors)
Posted: Mon Oct 20, 2014 8:26 pm
by Deano_123
It sounds awesome to drive, the noise on pull away in 1st is unbelievably loud, red lining in first through the middle of Newcastle more than likely made me look a dick but hey ho
I'll try a resonated pipe and see how that goes
Posted: Mon Oct 20, 2014 8:52 pm
by DaytonaRs4
Why don't you look at getting valves fitted to tubi backbox and keep the non res??..
Best of both worlds...
2x valves for my custom system were around £150 the pair iirc.
Posted: Mon Oct 20, 2014 8:55 pm
by Deano_123
DaytonaRs4 wrote:Why don't you look at getting valves fitted to tubi backbox and keep the non res??..
Do tell me more on this sir. As I thought this had been looked into before on the Tubi and was not possible
Did you use the setup from the original backboxes or complete from scratch?
Posted: Mon Oct 20, 2014 9:56 pm
by MikeFish
This is what I intended to do but never got round to it. Should be fairly easy being a quad exhaust to stick a valve on either the smaller or bigger tail pipe (not sure how much difference it would make going for one pipe over the other as they're fairly similar I guess).
Posted: Mon Oct 20, 2014 9:57 pm
by NJMAudiRS4
Does your Tubi back box have a twin exit exhaust into the oval tip or a single exit. If it's the twin then you can get valves fitted. If you go down the valve route try and get Bentley valves as they are less prone to seizing than Audi valves.
:beerchug:
Posted: Mon Oct 20, 2014 10:51 pm
by gt2
I have the normal Tubi and asked mrc if they could fit valves to it and was told they couldn't. If someone knows somewhere that can fit them I'd be interested to know
Posted: Mon Oct 20, 2014 11:22 pm
by MikeFish
NJMAudiRS4 wrote:Does your Tubi back box have a twin exit exhaust into the oval tip or a single exit. If it's the twin then you can get valves fitted. If you go down the valve route try and get Bentley valves as they are less prone to seizing than Audi valves.
:beerchug:
It's two separate pipes from each back box.
Posted: Mon Oct 20, 2014 11:23 pm
by DaytonaRs4
Complete from scratch. I wil try sort out some photos and info for you tomorrow
Posted: Mon Oct 20, 2014 11:24 pm
by NJMAudiRS4
Try J C Weldfab in Wellingborough, they build their own and also do bespoke fabrications, top blokes too.
Posted: Mon Oct 20, 2014 11:26 pm
by NJMAudiRS4
:beerchug:
Thanks Mike, should be able to do then with a competent fabricator :beerchug:
Posted: Mon Oct 20, 2014 11:29 pm
by NJMAudiRS4
gt2 wrote:I have the normal Tubi and asked mrc if they could fit valves to it and was told they couldn't. If someone knows somewhere that can fit them I'd be interested to know Image
NJMAudiRS4 wrote:Try J C Weldfab in Wellingborough, they build their own and also do bespoke fabrications, top blokes too.
