H&R anti roll bars
- RossDagley
- Top Gear
H&R anti roll bars
http://www.dpmperformance.co.uk/car-par ... attro-0905
I've been eyeing these up but would like some feedback from anyone who's got them already. I do track the breadvan (Nurburgring mostly) but do have to actually use it on british roads occasionally too - I don't want to give up the comfort the car gives on long hauls when needed.
Currently the setup feels close to ideal - I'm on DRC with SS+ - but I'd like a little less roll and a fraction less understeer on track. For the road I'd say it's about perfect as it is.
How are these bars likely to affect the car? Those who have them I'd be grateful for your input.
Previously:
Previously:
Re: H&R anti roll bars
I have these on my car (also H&R springs). Im on the softest setting and I haven't tryed different set ups yet. That being said... I really can feel how the turn-in is sharper and mid corner has more grip. Around the track I could feel being bit faster.
Sure the springs and bars will stiffen up the car, I love it. It's definitely not racecar stiff, more like fast sports car (which it is)!
Ross I think you'll love them. The car feels slightly stiffer if you hit a pothole but generally the comfort isn't too compromised. That said I haven't used these bars on this RS (as have added the SS+ bar for now) but I had them on an S4 (the RS4 bars in your link) and have uprated ARB's on all the Audi's I've owned (A, S and RS's). I had Hotchkis on my B5 RS4 with coilovers and the set up was awesome. The Hotchkis bars for the B7 I feel might be a step too far though (29mm rear but hollow).
Also there is only one option to really use. Full stiff front and rear.
EDIT to say whilst I thought the Hotchkis bars might be a tad too much for me personally, a lot of folk here have added them (as with the H&R's) and I've been in one on track (with KW v3 too) and the handling was / is superb, but I feel it would be a compromise on road in the long term.
Video from Hotchkis on the B7 RS: http://youtu.be/CKoCgUTk3ns
i have these on mine and set to the weakest of the 2 setting s i like the difference as the roll is noticably reduces , but one thing i have found ,, on 3 separate occasions when maybe a little hot going into a corner the back has stepped out and i have succesfully caught it , it may have been to other factors nothing to do with the roll bars , but i,m aware of it now so it has dulled my enthusiasm a tad , which may be a good thing
1/4 mile 12.01 secs 123.5mph
- 2nd Gear
I've fitted them on mine pal on stiffest setting!
Nothing with the ride has been compromised.
I run DRC ss.
Coupled with Michelin Cup 2 tyres and 10/8mm spacers it is so much more sharper and precise on turn in, back end feels planted.
Transformed car 100% imho....
Just find limit on open space for understeer
Go for it pal, got mine off Virdee off here, good deal.
I run DRC ss.
RS4 B5
Avus silver
Loba 600 turbos
Loba 750 clutch
Wagners
B7 brakes
Bilstein pss9's
641bhp/850torques
Avus silver
Loba 600 turbos
Loba 750 clutch
Wagners
B7 brakes
Bilstein pss9's
641bhp/850torques
- RossDagley
- Top Gear
Thank you all for your comments - seems to cement my views that it's a smart move to get these. Comments duly noted to find the limits somewhere other than the 'ring
Is there a lot of work to fit them myself or would I be better having MRC fit them (I'm competent just lazy!).
Cheapest I've found so far online is £373 from "Euro Performance" unless anyone knows somewhere cheaper than that?
Cheers again all
Cheers again all
Previously:
Previously:
Stiffening the front are should reduce body roll but also reduce front end grip. So under steer should be more rather than oversteer.rwilsonrs4 wrote:i have these on mine and set to the weakest of the 2 setting s i like the difference as the roll is noticably reduces , but one thing i have found ,, on 3 separate occasions when maybe a little hot going into a corner the back has stepped out and i have succesfully caught it , it may have been to other factors nothing to do with the roll bars , but i,m aware of it now so it has dulled my enthusiasm a tad , which may be a good thing
However the front end will react quicker to inputs so if you are hot with a change in direction it can unsettle things.
When during the corner does the back step out?
- corner entry / turn in? (are you trail braking)?
- steady state apex?
- corner exit under power?
Fit them yourself Ross, it's very very easy. I would advise using blue lock tight too! There is a guide on the Hotchlkis site and whilst the H&R bars attach differently at the end (front only I think) the guide will give you a general idea. When you remove the stock rear set it on the floor the same way it was on the car and then put the new bar next to it and then offer up to the car. I've not tried, but you might be able to attach backwards and therefore you want to avoid this for obvious reasons.
- RossDagley
- Top Gear
Thanks Marc I'll fit em myself then!
Previously:
Previously:
No probs, save yourself some cash. Report back when you'll tested it on your local racing circuit.
- RossDagley
- Top Gear
Do the H&R bars come with new bushes or should I be looking at some powerflex bushes or similar for this too?
Previously:
Previously:
Yeah its likely me going a little late and too much input , i dont think its the roll bars its me being too confident it has broken away at turn in at corner entry , the ESP has sorted it but it wasnt excessive just a bit unsettled , only a minor steering input was reguired ( i used to have a hot m2 escort so it was routine to correct slides without thinking )adsgreen wrote:Stiffening the front are should reduce body roll but also reduce front end grip. So under steer should be more rather than oversteer.rwilsonrs4 wrote:i have these on mine and set to the weakest of the 2 setting s i like the difference as the roll is noticably reduces , but one thing i have found ,, on 3 separate occasions when maybe a little hot going into a corner the back has stepped out and i have succesfully caught it , it may have been to other factors nothing to do with the roll bars , but i,m aware of it now so it has dulled my enthusiasm a tad , which may be a good thing
They come with bushes and bolts. Make sure you get the 32mm/24mm combo as they do a 32/22mm set too, double check when they arrive.RossDagley wrote:Do the H&R bars come with new bushes or should I be looking at some powerflex bushes or similar for this too?
Sounds about right - the tougher anti roll bar will make the front end react to steering inputs much quicker so moving the steering wheel the same amount and speed might unsettle the rear. Especially if you are trail braking and unloading the rear too.
This will be the next thing I am going for my set up already is Bilstiens and Super pro bushes
