front wheel spacers
front wheel spacers
Has anybody fitted 10mm spacers on the front. if so, do you have any rubbing issues? (rs4 b7). Thanks
MRC STAGE 2 RE-MAP
Re: front wheel spacers
I have 10 in front and 12 in rear. every once in a while I get a little rub in the front...but that's when I hit a massive bump going at a higher speed than I'd like. 99% of the time I'm fine. doooooooo eeeeettttttt
2007 RS4 | Phantom Black | Milltek'ed | LED DRL'ed | H&R wheel spaced | 034 Density Line control armed | Hotchkis F + R Sway Barred | K&N Filtered | Ziza lit | Lamix-ed | Passport 9500ix hardwired | Dension Pro BT'ed | StopTech Brake Padded
10mm front and no issues.... dont mind these 8mm guys and the world will end if you go any bigger
- RossDagley
- Top Gear
Their cousins are in the "100k miles and the engine explodes" tribe.edge wrote:10mm front and no issues.... dont mind these 8mm guys and the world will end if you go any bigger
Previously:
Previously:
- Surrey Sam
I have Super Sport suspension with 8mm on the front and I only get a little rub when coming off speed bumps, I personally wouldn't go with 10mm but the normal suspension option maybe fine with them.
RossDagley wrote:Their cousins are in the "100k miles and the engine explodes" tribe.edge wrote:10mm front and no issues.... dont mind these 8mm guys and the world will end if you go any bigger
- DaytonaRs4
anybody running KW's with 10/10???
2013 RS5 Phantom Black, MRC Stage 2 and TCU, Bilstein B16 IRC, 034 Arms, H&R ARB's, Milltek non res, ITG, 20” Ispiri FFR6 / PS4s, AP Radical 6 pot brakes / 390mm floaters, Pagid RSL1, JL Audio, EMtuning headlight build, Gtechniq ceramic and Llumar PPF
Gone: Daytona B7 RS4 saloon
Users browsing this forum: beckford21 and 254 guests
