Is it possible to change the control arms without disconnecting the shock form the DRC?
I have read it is possible but difficult and have had a quote from a VAG specialist to do the work that's cant do a DRC recharge so I assume it must be
Change upper control arms
Re: Change upper control arms
Yes I would say so,should be able to disconnect strut from the bottom arm and then undoe the strut top mount from the inner wing,you will have to work within the wheel arch which will be a pain but.....I had a specialist do the uppers on my RS but about to tackle it this weekend on my tdi.
- RossDagley
- Top Gear
Yes. I have had MRC change my upper control arms (and complete upright) and they "don't do" DRC.RS4_Ollie wrote:Is it possible to change the control arms without disconnecting the shock form the DRC?
Previously:
Previously:
What about changing springs without removing DRC pipe?
- RossDagley
- Top Gear
Yes springs can be changed without disconnecting DRC.RS4_Ollie wrote:What about changing springs without removing DRC pipe?
Previously:
Previously:
Users browsing this forum: No registered users and 499 guests
