Tumble flaps
Posted: Sat Sep 13, 2014 7:19 pm
by RS4_Ollie
Hi, Im going to do a carbon clean soon and was reading a lot of people remove the tumble flap.
What are the pros and cons of doing so?
:beerchug:
Re: Tumble flaps
Posted: Sat Sep 13, 2014 8:16 pm
by coffey555
Better airflow but slight loss of torque at lower rpm I believe.
I left my ones in after my carbon clean as there was no play in them.
Wiki says the tumble flaps are there to assist low engine speed combustion.
Re: Tumble flaps
Posted: Sat Sep 13, 2014 11:03 pm
by RossDagley
It runs a little more lumpy on part throttle openings, especially when cold. But the benefits are less restriction and less to gum up/go wrong!
Re: Tumble flaps
Posted: Sun Sep 14, 2014 12:39 am
by adsgreen
The tumble flaps simple close off half of the intake path leading to the cylinder. As it's low rpm this isn't a restriction but does have the effect of increasing the velocity of the air into the chamber so when the fuel is injected it can mix up a bit better.
If properly mapped there is no loss in power but will hit economy by a couple mpg when just pootling about
Re: Tumble flaps
Posted: Sun Sep 14, 2014 5:31 am
by RS4POWER
In order for you to remove the tumble flaps you will have to punch out the freeze plugs. There is a company out there that recommends reusing them by applying loctite upon reinstall but I strongly suggest you don't. New freeze plugs can be sourced (not by Audi) but you'll have to dig a little bit. PM me if you need them.
I have been running a deflapped p/p IM for years now with no adverse effects. Highest g/s I saw was 174 per bank. I believe with a tune that removes the tq limiter and considers less manifold restriction, p/p would tie in nicely. Perhaps Doug from MRC can chime in on this. :bigwave:
If anyone here is looking for a port/polished, deflapped IM (work performed by silverrs4) PM me, I have a spare one for sale.
Re: Tumble flaps
Posted: Sun Sep 14, 2014 1:36 pm
by skydude
I used a very small ratcheting wrench with a very short torx bit to remove flaps without touching the freeze plugs. Had them all out in 30 minutes
Re: Tumble flaps
Posted: Sun Sep 14, 2014 8:59 pm
by RS4_Ollie
If they aid low down torque I think I'll leave them in as it's a little lacking in the low torque dept.
:beerchug:
Re: Tumble flaps
Posted: Sun Sep 14, 2014 11:39 pm
by RS4POWER
SkyDude wrote:I used a very small ratcheting wrench with a very short torx bit to remove flaps without touching the freeze plugs. Had them all out in 30 minutes
This is good to know.
Re: Tumble flaps
Posted: Sun Sep 14, 2014 11:42 pm
by bam_bam
Haha, flaps...
Re: Tumble flaps
Posted: Mon Sep 15, 2014 5:08 am
by hlbeckley
coffey555 wrote:Better airflow but slight loss of torque at lower rpm I believe.
Hmmm I have a different view, I had low end torque pick up, albeit ever so slight
It is a bit lumpy below 3k revs when cold
The power gains post de flap and carbon clean are really very noticeable
No error codes yet either, I vote do it and add I take spacers too at same time
Re: Tumble flaps
Posted: Mon Sep 15, 2014 5:46 pm
by PetrolDave
hlbeckley wrote:The power gains post de flap and carbon clean are really very noticeable
Was the power gain due to de-flapping, carbon cleaning or both?
If you did them both at the same time then it's impossible to tell, but anecdotally carbon clean is worth c. 30bhp.
Re: Tumble flaps
Posted: Mon Sep 15, 2014 7:45 pm
by hlbeckley
Both same time but driven a de flapped post CC and flaps in, delivery is very different
