Torque reduction shifting into 2nd
Posted: Mon Sep 01, 2014 5:13 pm
by fredjudd
Before you read on this is not the torque limit applied via the throttle in 1st-3rd gears,
Evening chaps,
Recently I have been getting a torque reduction when shifting into 2nd. I can pull away normally, go full throttle in 1st then shift to 2nd and floor it again and I get about half a second of "dullness" before the engine springs back to lift. This has happened to be twice, once I shifted at 8k and the other was 6k, no ESP/TC light active on the dash.
Awaiting a friend to come and do some VAGCom logging, but anyone else had this issue?
Re: Torque reduction shifting into 2nd
Posted: Mon Sep 01, 2014 5:40 pm
by rob-s
Have you experienced the same with Traction Control (1xESP button) off?
Posted: Mon Sep 01, 2014 6:37 pm
by jaysrs4
You need to turn ESP off, then it won't do it.
Posted: Mon Sep 01, 2014 6:47 pm
by PetrolDave
jaysrs4 wrote:You need to turn ESP off, then it won't do it.
+1
Posted: Mon Sep 01, 2014 7:35 pm
by rwilsonrs4
yip+1
i get it more often as mine is charged ,damned annoying sometimes
Posted: Tue Sep 02, 2014 7:53 am
by fredjudd
Thanks for the replies chaps, I didn't think to turn that off because there was no indication on the dash that it was interfering! Shall test it later.
Posted: Tue Sep 02, 2014 8:09 am
by MikeFish
The light doesn't always come especially if it is only a quick one.
Posted: Tue Sep 02, 2014 8:11 am
by MikeFish
If it's happening in the dry on a straight then you need new / better tyres.
Posted: Wed Sep 03, 2014 10:29 pm
by Wavey Dynamicist
MikeFish wrote:If it's happening in the dry on a straight then you need new / better tyres.
Mine does it occasionally on dry and straight on hard changes and i have new Michelin Pilot Super Sports.. I don't think it's actually triggered by a loss of traction.. Something to do with the speed of throttle re-application and timing of the clutch i'm guessing, a pre-emptive thing.. Not sure why as it doesn't seem much use to be honest..
Quite a crude ESP system in general it feels in my opinion
Posted: Thu Sep 04, 2014 8:02 am
by adsgreen
It's better to prevent loss of traction than deal with it after it's already happening.
It's not crude at all - you have the eps fully on why would you want to unbalance and potentially upset the car.
Now... Mashing the throttle after a gear change... That's crude.
Posted: Thu Sep 04, 2014 1:52 pm
by Wavey Dynamicist
adsgreen wrote:It's better to prevent loss of traction than deal with it after it's already happening.
We're not talking about mashing the throttle after a gear change.. We're talking making a swift full throttle change from 1st to 2nd.. Nothing crude there..
Besides this is a four wheel drive car.. How much loss of traction are you likely to experience with zero or small steering angle?
Disable ESP and tell me if you see any loss of traction in the same scenario that the system cuts power with ESP fully enabled.. I never have..
Not to mention i've had it come in occasionally from 2nd to 3rd!
You may argue that the dynamics team did this in anticipation of wet driving.. To me having this feature active all the time is crude..
It is a crude system compared to current generation cars, but this is to be expected.. It wasn't so much a criticism but a statement.
Posted: Thu Sep 04, 2014 3:25 pm
by fredjudd
You mean you boys lift the throttle when shifting?!
Posted: Thu Sep 04, 2014 5:35 pm
by JoeyManhattan
fredjudd wrote:You mean you boys lift the throttle when shifting?!
I was surprised at that also, I always leave it to the floor...
