Anyone have their speed limiter removed?
Re: Anyone have their speed limiter removed?
My RS4 had the optional higher limiter from factory and (without being 100% as I was concentrating more on the tarmac than the speedo) I am sure I peaked at over 175.
MRC-TTS Supercharged B7 RS4.
- RossDagley
- Top Gear
I've had a GPS speed (with screenshot as was from video) of 179 with an indicated 185 on the dash. It was still pulling but I ran out of road/minerals.
I would say it's possible for a 190 on the dash, so perhaps a "real" 185 GPS speed. I had a CV boot fail at high speed once and the smoke out the back (as the grease hit the exhausts) scared the life out of me. Luckily wasn't anything worse.
Of course, the power of the car is limiting at these speeds - it maybe geared for 205 or whatever but aero means it cant get there without more power. The supercharged boys could chip in here and tell us their speeds
Previously:
Previously:
Danny's old car did 193 with c.630bhp.
Having done many high speed runs in many cars including B7 RS 4, B8 RS 5, C7 RS 6, R8 V10 / V8, TTRS, RS 3 ... I really struggle to believe the B7 will do any more than 170GPS unless you have a 4mile runway downhill and a tornado behind you.
- RossDagley
- Top Gear
I've had 170+ on GPS twice - the last time earlier in the week. It'll do it - but yes, it takes a while to get there.HYFR wrote:Having done many high speed runs in many cars including B7 RS 4, B8 RS 5, C7 RS 6, R8 V10 / V8, TTRS, RS 3 ... I really struggle to believe the B7 will do any more than 170GPS unless you have a 4mile runway downhill and a tornado behind you.
Previously:
Previously:
I recon 175 Max.
- RossDagley
- Top Gear
You have PMHYFR wrote:I recon 175 Max.
Previously:
Previously:
- PetrolDave
Drag is proportional to the square of speed, so for example 190 to 200mph is a 5% increase, but drag goes up by over 10%.RossDagley wrote:but aero means it cant get there without more power.
Top speed is, for the vast majority of road cars, limited by drag rather than gearing - the B7 RS4 being no exception.
You need to jump in my RS4 then and get your GPS out as and see if it matches mine as mine shows 187mph and 192mph on my clock.HYFR wrote:Having done many high speed runs in many cars including B7 RS 4, B8 RS 5, C7 RS 6, R8 V10 / V8, TTRS, RS 3 ... I really struggle to believe the B7 will do any more than 170GPS unless you have a 4mile runway downhill and a tornado behind you.
Were you being towed by a Veyron?
Tipped a speedo indicated 193 in my mrc mapped b7
Saloon with de coke gutted pre cats an milly !!
And it got there in no time !
HYFR wrote:Were you being towed by a Veyron?
Thank you Afsimba that makes two of us, mine has not catsAfsimba wrote:Tipped a speedo indicated 193 in my mrc mapped b7
HYFR nope just in his slip stream
- esp_mm-270
Top speed =193 mph (need forced induction to get there). 200+ is possible with one of the superchargers but final drive needs to be adjusted. Very expensive to do properly but I figure if you keep the same tyre width and profile but with 20" wheels you'll have enough 'gearing' to clear 200mph.
I've only got to 160mph (up hill) but it was still pulling very hard so I figure about 180mph but that has been generally dismissed by others here
Next time i get a chance i'm gonna set up video of a VMax attempt so we can put this to rest! Hah
2007 RS4 Saloon; Mugello Blue
- RossDagley
- Top Gear
I've put this to rest already :p
178mph/GPS - on video (185mph indicated). And I backed off because a cv boot split and I don't have the minerals to do it again :p
Previously:
Previously:
Users browsing this forum: Google Adsense [Bot], Majestic-12 [Bot] and 222 guests
