just curious to know what pressures most folk are using with their stock rims and rubber. The 'book' says 38 psi with 42 psi listed for heavy loads. I find I tramline a lot with 38psi - does anyone else increase the pressure a little to reduce this?
Mak.
Tyre Pressures on standard 19" rims / tyres
2013 Guards Red 991 Carrera - VERY MUCH Arrived.
2013 Ibis White RS4 B8 - Gone
2007 Phantom Black Avant RS4 B7 - Gone
Re: Tyre Pressures on standard 19" rims / tyres
I always do 38/35 front/rear on summer tyres. It doesn't tramline. Maybe you need a realignment?Spectre wrote:just curious to know what pressures most folk are using with their stock rims and rubber. The 'book' says 38 psi with 42 psi listed for heavy loads. I find I tramline a lot with 38psi - does anyone else increase the pressure a little to reduce this?
Mak.
- PetrolDave
+1stu wrote:I always do 38/35 front/rear on summer tyres. It doesn't tramline. Maybe you need a realignment?
Also, have a Hunter 4 wheel alignment (not just tracking). Made a difference to mine
Thanks Gents - will hunt down a hunter in the East Mids - (Anyone know of one in East Mids?)
I used one in Leicester and they had an RS6 in at the same time as well. They have 2 Hunter set - ups there. I can't recall the name of the place right now but I can dig it out if you are interested.
Something like alignmycar.com shows all places with hunter kit
Users browsing this forum: No registered users and 214 guests
