Need new clutch :(
Posted: Thu Aug 14, 2014 8:46 pm
by Shaners4
Right folks I've done a few searches on here and need some advice still. My clutch on my saloon is really sticky and feels like its about to go! When I put my foot to the floor in any gear and dont touch the clutch it just revs the nuts of itself and goes no where, Whats likely to have going the whole clutch system and whats the best to put in and where can I obtain such a part from :boohoo:
Re: Need new clutch :(
Posted: Thu Aug 14, 2014 9:18 pm
by lengster1
Standard clutch is fine,euro car parts may have a deal on or try local suppliers,Luk is the oe manufacturer from memory,I would do the flywheel at the same time if I were you.Think I had mine done all in for around 1700
Posted: Thu Aug 14, 2014 9:45 pm
by Shaners4
ouch :bash:
Posted: Fri Aug 15, 2014 2:49 am
by stu
Them or TPS - they may discount as well. All the part numbers can be found via the FAQ sticky or check my recent posts - I uploaded part of my invoice last week which included the clutch items if you want to double check.
Posted: Fri Aug 15, 2014 9:47 am
by sync24
Mine is in for a clutch pre spa @ MRC [It's sticking and the car has 78k] - I shopped around for ages - uhm'd and arrr'd over LOBA / SMF v DMF - got 3 quotes AMD, MRC & 4 Rings + Stoke Audi for the parts - MRC came out matching stoke Audi for the parts cost [All OEM]
Doug mentioned that the master cylinder does not need replacing at clutch swap time unless faulty - all other components do.
Here is the list with prices:
OEM DM Flywheel £797.50 [SM is £370 + VAT]
B5 Needle Bearing £35.41
Flywheel Bolt 10x £27.90
B7 Friction Plate £110.30
B7 Pressure Plate £113.69
B7 Release Bearing £31.60
Clutch Bolt 6x £2.82
B7 Slave Cylinder £78.99
B7 Slave cylinder pipe £17.91
£1216.12 + VAT = £1459.34 parts
£652.80 [Incl. VAT] MRC labour [8 hrs]
Posted: Fri Aug 15, 2014 11:10 am
by toyneg
I am not looking forward to this bill when mine finally goes
Posted: Fri Aug 15, 2014 11:36 am
by Rick_RS4
toyneg wrote:I am not looking forward to this bill when mine finally goes
Ouch me neither
Posted: Fri Aug 15, 2014 3:22 pm
by Scott Long
My vote goes for JHM R-series clutch with stage 1 disc and a lightweight single mass flywheel.
Posted: Fri Aug 15, 2014 5:58 pm
by AdrianD
Do you need to change the flywheel every time or is it more a may as well do it while its apart job?
Posted: Fri Aug 15, 2014 6:37 pm
by Scott Long
I've been told the dual mass flywheels are harder to properly resurface and they can come apart and fail and cause major damage to the transmission when they fail.
It's one of those things, since its taken apart, might as well spend money now to upgrade and not have to worry about it for a long long time.
