JHM stage 1 supercharger kit
adsgreen
Re: JHM stage 1 supercharger kit
Post by adsgreen » Wed Jul 16, 2014 3:42 pm
stu wrote:...and what's that weird thing where the battery should be in the JHM pic?
Looks like part of the charge cooler. There are some pipes leading away from the bit connected to the intake round to the left and through to the battery compartment.
My guess is that it is the coolant pump?
Timster
Post by Timster » Wed Jul 16, 2014 4:10 pm
Hang on... isn’t that where the hydraulic top-up normally is ?
stu
Post by stu » Wed Jul 16, 2014 4:27 pm
vs.
Maybe someone can confirm that that second photo is indeed a standard S4 engine bay since I'm just googling.
adsgreen
Post by adsgreen » Wed Jul 16, 2014 4:50 pm
Guessing the brake fluid header tank location is dependant on LHD or RHD?
stu
Post by stu » Wed Jul 16, 2014 5:14 pm
I reckin the battery cover is just resting over brake fluid header tank. Doesn't look slotted in place.
adsgreen
Post by adsgreen » Wed Jul 16, 2014 5:20 pm
so guessing they have replaced the battery with the charge cooler however on the rs4 that's where ECU2 is located. Probably easier to relocate that than a big heavy battery
sar
Post by sar » Thu Jul 17, 2014 1:24 pm
stu wrote:Image
from what i know about the intercooler setup which isnt a lot, red box is the coolant tank, the green box is the charge cooler and there will be a pump and rad upfront somewhere.
and yes the difference in position of the ecu and hydraulic/brake servo is one of the differences between r/h/d and l/h/d. for a stage 2 kit for the uk the tank will have to go on the opposite side and the pipes to the charge cooler will need extending.
b7rs4 phantom black, titan pack.
adsgreen
Post by adsgreen » Thu Jul 17, 2014 1:28 pm
<pedant mode>technically its an aftercooler not an intercooler</pedant mode> ;)
Timster
Post by Timster » Thu Jul 17, 2014 11:25 pm
"and yes the difference in position of the ecu and hydraulic/brake servo is one of the differences between r/h/d and l/h/d. for a stage 2 kit for the uk the tank will have to go on the opposite side”
Doh, yes, I’d forgotten about that.
sar
Post by sar » Sun Aug 03, 2014 11:40 pm
finally got round to starting this install, not sure how long it will take as me and a friend are doing all the work as and when we get time. having said that we have made decent progress so far!.
got to find room in here for a supercharger!.
bonnet off to make a bit of room.
all this has fit somewhere!
new oil and filter, fuel filter, new spark plugs, new one way valve for the vacuum system.
flying_tomatoes
Post by flying_tomatoes » Sun Aug 03, 2014 11:43 pm
Excited to see that your doing this your self! Post lots of pics!
2007 RS4 - Bagged and Blown. IG: @Flying_Tomatoes
stu
Post by stu » Sun Aug 03, 2014 11:46 pm
flying_tomatoes wrote:Excited to see that your doing this your self! Post lots of pics!
+1 :nodder:
sar
Post by sar » Mon Aug 04, 2014 12:00 am
bumper off and crash bar removed, time to drain fluids.
unplug headlights and crash sensors, detach radiator hoses and a/c lines and remove oil cooler lines from the block and the front panel lifts off as one.
leaves this
Rick_RS4
Post by Rick_RS4 » Mon Aug 04, 2014 12:18 am
nice progress
lengster1
Post by lengster1 » Mon Aug 04, 2014 9:19 am
Good effort! Keep us all posted
Users browsing this forum: No registered users and 267 guests
