Page 1 of 3
Spacers Size Question.... I searched.. honest
Posted: Thu Jun 26, 2014 4:11 pm
by edge
Everyone seems to go 8/10, there’s many pics out there for this.
I am running OEM wheels and standard tyre size also.
Is there any issue with 10m on the fronts? Seems the only negative is with a wider tyre or a chav look....
Any advice and pics of a non 8/10 car with similar wheel/tyre size would be great, want to order some this week.
Re: Spacers Size Question.... I searched.. honest
Posted: Thu Jun 26, 2014 4:23 pm
by flying_tomatoes
if your running a 255/35 you will be fine with a 10mm. You might need to remove the top screw in your fender liner as that is the most common area for rubbing. Here's a shot of my car lowered on Stasis/Ohlins and 10mm spacers front and rear. OEM 255/35/19 on stock wheels.
Posted: Thu Jun 26, 2014 4:59 pm
by neilparf
edge wrote:Everyone seems to go 8/10, there’s many pics out there for this.
Edge - I've just done spacers and I've gone for 8mm all round - I have SS+ so, on the advice of Virdee (top bloke) went 8mm all round. No issues rubbing and looks spot on
Posted: Thu Jun 26, 2014 5:13 pm
by toyneg
great mod spacers! massively improves the look of the car IMHO
Posted: Thu Jun 26, 2014 6:33 pm
by scaghead
toyneg wrote:great mod spacers! massively improves the look of the car IMHO
Plus 1.... I am running 8/10s as well...but on 265/30/19s
Posted: Thu Jun 26, 2014 6:36 pm
by rwilsonrs4
i was running 8 and 10 with 255/35/19 contis but when i fitted GY F1 assy 2 they were rubbing on the arch liners due to the squarer profile and sidewall protectors so took them off
Posted: Thu Jun 26, 2014 7:27 pm
by neilparf
rwilsonrs4 wrote:i was running 8 and 10 with 255/35/19 contis but when i fitted GY F1 assy 2 they were rubbing...(
Heard that - I run conti's but plan to to run GY F1 and heard the GY F1 do rub, hence the 8mm all round... fingers crossed...
Posted: Thu Jun 26, 2014 7:37 pm
by Timster
I run exact same with GY F1 Assy2’s.
Never had a problem.
Posted: Thu Jun 26, 2014 8:45 pm
by rwilsonrs4
well in fairness it was only when cornering hard or belting down the back roads through dips etc but it was annoying
by rwilsonrs4
Posted: Thu Jun 26, 2014 8:51 pm
by rob-s
I have A5 wheels at the moment 19"x9"et33 and use 11mm at front and 17mm at rear that corresponds with 7mm and 13mm. SS+ suspension and 225/40-19 PS2 tires..no rubbing!
Posted: Thu Jun 26, 2014 8:55 pm
by fredjudd
Mine on 10mm spacers currently but they are coming off. Looks good but the man from audi designed the car for a certain track width which I would like to return to.
Posted: Thu Jun 26, 2014 9:00 pm
by vwgolf32
Standard wheels running 255-35-19 cont have 10mm rear and 8mm with no issues
Posted: Thu Jun 26, 2014 9:45 pm
by Rick_RS4
You haven't searched very well. This gets asked every week
Posted: Thu Jun 26, 2014 10:04 pm
by edge
Ha ha there's only 3 posts with information about non 8/10 spacer people...bit like what what I noticed when searching for spacers.
Thank you guys, for the pics, thinking of heading off the beaten track and going 10/10.
So the only fear of 10mm fronts is possible rubbing on one screw or if you have a wider tyre or non OEM wheel.
