RS4 B7 2006 - Different thread question
- 2nd Gear
Here's one I need help with that's not been seen before!!
I've fitted spacers (20mm) on my car from previous owner and I've just noticed my rear NS wheel protrudes further out than my NS. Checked spacers and they are defo the same width!
Any ideas how this is and if I'm facing further issues??
Weird I know but on close inspection it's defo right what I'm implying!!
Advise guys!!???
Advise guys!!???
Modified standard exhaust Modified deflapped inlet manifold ported and polished
Head and valve decoke Performance K&N panel filter. Remapped. Lowered slightly (20mm) on KW performance springs Widened on 10mm spacers.
Re: RS4 B7 2006 - Different thread question
Different offset wheels? Rear subframe not centred? Are the spacers sitting correctly centred on the hubs?
Cut and shut?
Do you mean nearside rear sticks out more than nearside front? Or nearside rear and offside rear?
If nearside rear and near side front then you are supposed to use different size spacers front and rear.
Cut and shut?
Misano Red RS4 B7 Avant
- 2nd Gear
Sorry mate, NS Rear protrudes out more than OS Rear and all my spacers front and rear are the same!coffey555 wrote:Different offset wheels? Rear subframe not centred? Are the spacers sitting correctly centred on the hubs?
Cut and shut?
Any ideas it's got me puzzled
I think the front spacers are normally 8mm and the rears 10mm with standard ET29 wheels but others on here can confirm.
Bit odd at the back though. You can take the rear wheels off and check the offsets are correct. They should both have ET29 on them if they are the standard 19's. Are both tyres the same size as well?
Are the hubs free of corrosion?
Stick some pictures up if you can.
have you def got original wheels and not S4 'rs style' versions? how much further does one wheel petrude to the other, is it really noticeable?
my rear offside sticks out about 4mm more than the near side
- 2nd Gear
Yes original OEM wheels correct offset no corrosionamd 10mm spacers all round correct tyres and it sticks out approx 4mm more also.coffey555 wrote:I think the front spacers are normally 8mm and the rears 10mm with standard ET29 wheels but others on here can confirm.
Most odd. Get it up on a ramp and have a good look.
Loving the yellow brakes though!
I have 10mm spacers at the back and my ns protrudes slightly more as well, only noticed yesterday
- Tile Diver
Possible previous damage to the wheel arch, and may not have been repaired to exact position as standard??
Black Optics / Ti Pack
SS Suspension +
Sunroof
H&R Hubcentric Spacers
Milltek Res / Valved Cat Back
Stage 2 MRC Map
Cold Air Feed
Carbon Clean
Pre-Cats Gutted
447 PS
If in doubt.. Power out!!
SS Suspension +
Sunroof
Stage 2 MRC Map
Cold Air Feed
Carbon Clean
Pre-Cats Gutted
447 PS
It's not uncommon. Lots of cars are like this, particularly cars of a certain weight and torque, not a lot you can do about it except keep your suspension components checked and get alignment done twice a year.
Mine was like this and I only noticed when I fitted my new wheels. Rear sub frame was off about 3mm. I went and got tracking done and they said it was spot on. Was only when we did a full sub frame inspection that we noticed it was slightly out. Took it to work, chucked it on the ramp and adjusted it my self. Perfecto now abd only took 10 mins.
- 2nd Gear
chunky79 wrote:Mine was like this and I only noticed when I fitted my new wheels. Rear sub frame was off about 3mm. I went and got tracking done and they said it was spot on. Was only when we did a full sub frame inspection that we noticed it was slightly out. Took it to work, chucked it on the ramp and adjusted it my self. Perfecto now abd only took 10 mins.
Thanks guys I will get the sub frame checked out!!
Users browsing this forum: r8wut and 255 guests
