RS sticker in engine bay
Posted: Thu Mar 27, 2014 10:37 pm
by maizyboy
Evening all. I'm sure I'm not the only B7 RS4 owner to be suffering from the dreaded peeling RS
Sticker that sits atop one of the plastic covers in the engine bay. Anyone had any success in finding a way to keep it stuck down? Do I need a new one, can it be stuck down, if so what did you use? I've tried a few glues from around the house but to no avail. Any help would be much appreciated.
Re: RS sticker in engine bay
Posted: Thu Mar 27, 2014 10:45 pm
by sync24
maizyboy wrote:Evening all. I'm sure I'm not the only B7 RS4 owner to be suffering from the dreaded peeling RS sticker that sits atop one of the plastic covers in the engine bay. Anyone had any success in finding a way to keep it stuck down? Do I need a new one, can it be stuck down, if so what did you use? I've tried a few glues from around the house but to no avail. Any help would be much appreciated.
As the part gets hot, most regular sticker glues will go off - dare I say something like superglue or epoxy based ? Just something that's heat resistant.
Posted: Thu Mar 27, 2014 11:17 pm
by CellDamage
I have this too, perhaps a spot of Araldite?
Posted: Thu Mar 27, 2014 11:30 pm
by sar
i went to a sign place and asked nicely if i could have a scrap of red vinyl and cut out a new one.
Posted: Fri Mar 28, 2014 12:02 am
by neilparf
I had this and used the slightest bit of modellers Cyanoacrylate 'grip glue'. It's very thin but very high 'stick'. Araldite etc is too think and I'm not sure would leave the cleanest of edges...
The vinyl sar mentions is a good idea - the vinyl adhesive may cure and dry after a while be easy to keep doing it with some spare red...
Posted: Fri Mar 28, 2014 1:14 am
by Rick_RS4
superglue and apply it with a pin
Posted: Fri Mar 28, 2014 1:57 pm
by jaysrs4
Red model enamel all the way. I did the same with vinyl too, the enamel shines better
Posted: Fri Mar 28, 2014 7:21 pm
by coffey555
I went with OEM and left it semi-unstuck.
Posted: Fri Mar 28, 2014 8:46 pm
by Audi Pardner
Used double sided tape (the type you get from office supply shops). Worked fine; I didn't remove the
Sticker, just popped a small piece of the tape under the exposed corner.
Posted: Fri Mar 28, 2014 9:22 pm
by Iain_S4
coffey555 wrote:I went with OEM and left it semi-unstuck
+1
Posted: Fri Mar 28, 2014 11:21 pm
by Covkiller
