Replacing exhaust flexis
Posted: Sat Mar 15, 2014 10:54 pm
by webster444
Both my exhaust flexis between the cats are damaged right through and now leaking. With MOT time coming up I will need to replace them.
Anyone know where is best to buy the replacement flexis?
What grade of steel is the exhaust so I know what filler wire to get for my mig?
Ta much
Re: Replacing exhaust flexis
Posted: Mon Mar 17, 2014 8:46 pm
by webster444
Anyone any ideas?
Posted: Mon Mar 17, 2014 9:45 pm
by WilkinsonRS4
Instead of putting new flexis back on why not weld in stainless steel pipes hence no corrosion ever again and better air flow!!!
Posted: Wed Mar 19, 2014 1:20 pm
by webster444
Id prefer to stick flexis in again so I dont have any potential vibration related cracks forming
Posted: Thu Mar 20, 2014 4:14 pm
by WilkinsonRS4
webster444 wrote:Id prefer to stick flexis in again so I dont have any potential vibration related cracks forming
Ye your right!! I need to locate flexis too I've found a place in Liverpool that I've spoken too but they need dimensions and OD have you got the dimensions and spec etc??
Posted: Fri Mar 21, 2014 10:08 am
by toyneg
i had mine checked at a local (ish) exhaust specialist, he was going to charge £150 all in to replace both but he was good enough to be honest and said although slightly scuffed/damaged they weren't leaking so he said not to bother :)
Posted: Fri Mar 21, 2014 1:12 pm
by webster444
Not sure on the dimensions of them, 2.5" diameter is all I know at the moment. Im offshore at the moment so will have to have a look when I get home.
Mine are definitely holed right through so will fail an MOT.
Anyone know what grade of stainless welding wire is all right to use to a varied range of stainless grades?
Posted: Mon Mar 24, 2014 12:56 am
by WilkinsonRS4
webster444 wrote:Not sure on the dimensions of them, 2.5" diameter is all I know at the moment. Im offshore at the moment so will have to have a look when I get home.
Go to jcwhitney.com mate
